No Burbles
Old Jul 24, 2020 | 04:43 AM
Idklol69's Avatar
CLS400 4Matic EC Tuned
No Burbles
Have a tune through Eurocharged and I hear absolutely zero burbles throughout the entire RPM range. Windows down and tried listening for it but there was nothing. Any suggestions? I feel like the dude in this video lol:
Old Jul 24, 2020 | 10:10 AM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Originally Posted by Idklol69
Have a tune through Eurocharged and I hear absolutely zero burbles throughout the entire RPM range. Windows down and tried listening for it but there was nothing. Any suggestions? I feel like the dude in this video lol: https://www.youtube.com/watch?v=EedAWDj_zSI
gun it in 2nd and lay off the gas. If the car isn’t doing it there could be a pending code for an issue. The car stops burble by design if that happens
Old Jul 24, 2020 | 09:58 PM
Idklol69's Avatar
Still nothing.. Might just upgrade to CLS63 mufflers..
Old Jul 24, 2020 | 10:01 PM
loungn14's Avatar
SPONSOR
check pending codes First
Old Jul 24, 2020 | 10:02 PM
Idklol69's Avatar
What do you mean pending codes?
Old Jul 25, 2020 | 04:21 PM
cls5504matic's Avatar
C63 Vert
I just got a tune as well that doesn’t feel perfect for the car and perhaps waiting on codes. (Between 3-4k rpm when it would boost on stock tune the fuel cuts out like the computer is holding it back.)
my car does actually burble tho even tho I wasn't expecting it too (maybe I got your burbles).
I deleted the mid resonators and the tune def made it burble. Maybe not like a jaguar but when slowing down even on stock tune it still burbles now.
Old Jul 25, 2020 | 04:45 PM
usc96's Avatar
2019 AMG E53 Cabriolet
If I gun my car while it is in Sport+, then let off the gas, it will make those popping and crackling sounds as the revs drop into the 4,000 - 5,000 RPM range. I assume that is the burbling sound you are talking about?
My guess is the gas mixture is too rich, leaving gas to be ignited after the piston stroke which results in the popping sound.
Interesting gimmick, but gets old quick.
Old Jul 25, 2020 | 05:59 PM
Idklol69's Avatar
Is the resonator delete the only mod you've done to your exhaust? Is there drone on the highway?
Old Jul 26, 2020 | 01:09 AM
Roop94's Avatar
W218 Stage 2, E85
I have the mufflers on and I get the pops with regular Stage 2 tune and I asked for a file with burble tune and that file completely got rid of the pops. It was weird. Jerry re-did the burble tune for the 2nd time, still nothing. No pops on burble tune. So I switched back to the original Stage 2 file and the pops are back. I get the pops on revs and pretty much all the way down to 2k RPM. I haven't tested them from the redline, but they usually come alive between 2k to 5k rpm. Upgrading the AMG muffs probably won't change much besides the exhaust tone. But not the pops. Check with Jerry or check for any pending CEL codes on your car. Run a diagnostic on your car via OBD2 and the scanner might have "Pending Codes," that are lingering in the system to pop up, but haven't yet. For example, say your fuel injector is not functioning at its full capacity. So it might not throw a CEL at you right away, but it gets stored in the Pending Codes category that sometime soon that code will throw a CEL, but not yet.
Old Jul 27, 2020 | 06:19 AM
Idklol69's Avatar
Yeah, both my files can't get the exhaust to burble which is unfortunate. I wanted to upgrade the mufflers because I've seen some people with C400's replacing their mufflers with C43 (performance exhaust ones) and you can pretty much replicate the sound of a C43. Can't really find those but CLS63 ones are easier to find and would be an easier fit I think. Tbh I don't have a diagnostic tool or know anyone with it. Not too sure if I want to go out of my way to go to a local shop just for this specific thing. Even if there are pending codes, would EC even be able to do anything on their end by sending a new tune?
Old Jul 27, 2020 | 08:07 AM
hyperion667's Avatar
2012 CLS63
This thread is awesome!
Old Jul 27, 2020 | 05:47 PM
Roop94's Avatar
W218 Stage 2, E85
That I do not know, personally. I only mentioned and explained about the pending codes because @loungn14 mentioned it above. Idk if they do play a role or not. I would best check with Jerry who sent you the tuned ECU file or Loungn14 and see what it could be.
However, I have a few questions:
1. Are you running a regular Stage 1 tune?
2. Are you running Stage 1 tune with burbles?
3. Are you running Stage 2 tune (with cat-less down-pipes)?
Old Jul 27, 2020 | 06:13 PM
Idklol69's Avatar
I have two files, stage 1 with the gains, and another file with the gains + the burble. I run the regular stage 1 but I've tried the burble one 3x but no luck. Everything else including the exhaust is stock.
Old Jul 27, 2020 | 06:41 PM
Roop94's Avatar
W218 Stage 2, E85
Ok, there should be burbles then. Check with EC about it. I was running Stage 1 with Burbles and i had plenty pops during declaration.
Old Jul 27, 2020 | 07:28 PM
Dblok1113's Avatar
2014 CLS 550
I would do a cat delete, I got burble action off cat delete alone not a lot but a few then added catless dps had even more when which I was surprised myself then added state 2 tune from Weistec which has been an ABSOLUTELY AWESOME EXPERIENCE ! I didn’t choose burble option because it already did enough for my liking but either way I bet if you do a cat delete or res delete whichever is the one where an x pipe would go, and run a straight pipe where the cats were you will get a much better sound and didn’t even get a check engine. My .02
Old Jul 27, 2020 | 07:34 PM
Dblok1113's Avatar
2014 CLS 550
Old Jul 27, 2020 | 07:38 PM
Idklol69's Avatar
I mean the thing is, is that it doesn't burble at all, like you don't hear one burble. There's videos of stock C300's/E300's with completely stock exhausts that burble plenty. After I get it to burble, I could do what you're saying to get more aggressive ones though.
Old Jul 27, 2020 | 08:17 PM
Dblok1113's Avatar
2014 CLS 550
I gotcha, I was thinking if you removed them it might be an alternate solution to getting it to burble but yeah man if other stock 300s are doing it with no problem you shouldn’t be having a problem either, I hope you find the solution
Old Jul 28, 2020 | 01:15 AM
Idklol69's Avatar
Was told by EC to install the burble tune and then disconnect the battery for 5 minutes and then try. Will be doing this tomorrow and see if it works.
Old Jul 28, 2020 | 07:13 PM
Idklol69's Avatar
So I tried it today and it didn't work. Was told by EC if this doesn't work it's an ECU issue..
Old Jul 28, 2020 | 10:53 PM
Roop94's Avatar
W218 Stage 2, E85
I had the same issue when I requested for a burble tune for Stage 2. It didn't work as EC said and I disconnected the battery for 2 hours, but still, didn't work as expected. So I went back to the original Stage 2 tune.
But one thing I would advise is not to run a burble tune with cats on. It can or will, after a long time, damage the cats because you're dumping extra unburnt fuel into the exhaust and cats don't do well with unburnt fuel. Some might experience this damage quickly, very late, or never. But there is a potential for the cats to go bad. My O2 sensor went out which I believe was due to the burble tune in December 2019. But, that was for me. you might never experience it. Just saying.
Old Jul 29, 2020 | 12:18 AM
Idklol69's Avatar
Yeah I know the risks associated w/ running it with cats, I only wanted it for the summer months tbh. Sucks that it's not working for me because the weather is beautiful right now here.
Old Jul 29, 2020 | 01:09 AM
Roop94's Avatar
W218 Stage 2, E85
Lol I might've mentioned the risks of running burble with cats on to you earlier as well. I don't remember lol so my apologies for trying to be a smartass lol But yea, talking to Jerry would be the best option here since he makes the tunes. He couldn't fix my Stage 2 burble tune. He gave up after 2 additional files lol said it will have to be a custom file and that would be extra...so I just let it go.
Old Aug 7, 2020 | 09:55 PM
C63 Vert
No drone on highways it is awesome. It is grown up but loud like a boat on cold start and under throttle. There is an extremely minimal, almost imperceptible, amount of resonance decelerating around town when I'm running a tune.
I put together this site, tunedmercedes.com, last night and it was one of the first things I posted: http://tunedmercedes.com/performance/resonator-delete/
I also did UPD air intake spacers and K&N filter, that made a pretty big difference as well in terms of intake sound and power.
Old Aug 14, 2020 | 11:36 PM
Idklol69's Avatar
Asked for a tune with just the burbles and it worked. I can't really hear them how they sound like from the outside on the inside even with the windows down, but when you're outside listening to it, it sounds good. Everything on my exhaust is stock, so the burbles are more quiet, but sometimes there are more violent ones at 4-5k rpm. It smelt bad when I was revving it in park after I flashed it. Do any of you think CLS63 mufflers would improve the burbles?
