CLS Wheel weights
Has anyone ever weighed your wheels? It would be nice to see what weights you got.
In this website there is HUGE numbers on CLS550 19" rims https://www.rtwwheels.com/2015-123/ front wheel is 38lbs=17,2kg and rear wheel even worse 40lbs =18,1kg
Can those rims be really so heavy, what do you guys think? For now I have those rims on my car... lol
I have forged Ferrada F8...I was told that they weigh about 25-27 lbs. But maybe I should have weighed them when they came in. I should try to do that when I replace my tires. Wonder when that will be, I have plenty of treads left on them.
But I don't think they will install tires on aftermarket wheels, do they? Because this one shop where I regularly go, he damaged the rim of my wheels a bit. And that ******* had the audacity to say that they were already there. If they damage the wheels again, I'm requesting a replacement. lol
Mine are stock, OEM 18" AMG style, but still curious about the weight, since they're not forged. And i've yet to hear about them not working with aftermarket wheels.
I will weigh my 19" AMG style wheels tomorrow and see what numbers I get.
I don't know, I thought they didn't do aftermarket wheels because they didn't meet the factory specs. I'm planning to put up 305 30 20 on the next round.
Front: A2124012702 9 x 19 ET37 28,6lbs = 13 kg
Rear: A2184012002 10 x 19 ET47 29,7lbs = 13,5kg
Same wheels like these https://www.ebay.co.uk/itm/4-AMG-Win...oAAOSw7eFZ3JQZ
Those are bit heavy too, but if we compare the stock 19" front 17,2kg and rear 18,1kg the difference is big. I did gain front 4,2kg/ side and rear 4,6kg/side rotating mass. (Im still hard to believe that 17,2kg and 18,1kg weights)
EDIT: In this website also it tells that CLS550 OEM 19" rear wheel 2224011402 weight is 40lbs=18.1kg ! https://allusedrims.com/product/afw8...ed-2224011402/ So it seems that I have gain a lot rotation mass off when I will put those AMG forged wheels to my car. I think I will see some performance gains there also
If those weights are true, the total rotation weight reduction is 38,8 lbs=17,6kg!Heres a page for info rotation mass reduction benefits: https://www.cjponyparts.com/resource...nsprung-weight
So if anyone knows a light weight (19lbs-23lbs max) 19" wheels that can be used on our cars it would give me more choice to think what wheels im going to buy. Please share what brands there are in USA etc.
I can't say anything on other brands since...1) I don't have 19-inch wheels. @2) I didn't weigh my 20s, so I can't even take a guess.
The best bet is to find the wheels you like and contact that company on IG or FaceBook or just give them a call to verify the details.
Heres the final results what I have scaled. Maybe someone like the info someday when comparing and wanting to reduce rotating mass:
CLS63 AMG 19” OEM Forged wheels
Front: A2124012702 9 x 19 ET37= 28,6lbs/13,1 kg +255/35 PZero= 52,2lb/23,7kg
Rear: A2184012002 10 x 19 ET47= 29,7lbs/13,5kg +285/30 PZero= 54,4lbs/24,7kg
CLS500 OEM 19” wheels
Front: 2184012502 8,5 x 19 ET34,5 29,7lbs=13,5kg +255/35 Nokia wr4= 57,1lbs/25,9kg
Rear: 2224011402 9,5 x 19 ET43,5 33,1lbs=15k g +285/30 Nokia wr4= 60,8lbs/27,6kg
So im looking for wheels that weight 19-22lbs and with the tires the weight would be like 40lbs. So you can see how much less rotating mass I have after that. I will effect the performance for sure. the weight reduce is so big.
Heres a good test and writing about performance increase, when lighter wheels are installed: https://grassrootsmotorsports.com/ar...really-better/
in this Saturday im going to try to fit used TSW Bathurst 19x8,5 ET32 rims with Michelin pilot sport 245/35 tires to my car front and rear. They are 19,4kg each. If they will fit like they should, im going to buy those. It will def increase performance. Like I have written and scaled my original wheels with tires the rotating weight loss will be huge.
Next rims will be OZ Ultraleggera HLT. Let see what will happen.
They will arrive in February to me. Weight reduce will be about 5kg/rear wheel and 3kg/front wheel = 16kg.
Front: 19x8,5 ET25 255/35 Pirelli PZero
Rear: 19x9,5 ET 30 285/30 Pirelli PZero
Total rotation mass reduce gain was 15kg/33lbs compared to stock OEM 19" wheels.
And that can be feel on handling and braking, also accelerating. I haven't try Dragy yet, because its too much snow and slippery here in FinlandIf someone want to get those wheels to CLS550 be ready to grind some stuff off from front calibers. After that they fit well.
So when you buy new rims check the wheel weight if the performance is important to you.
