Side Marker Bulb Replacement
Old Feb 19, 2022 | 06:00 PM
trublu97's Avatar
CLS 550
issue- Side Marker bulb burned out, needs replacing.
Has anyone attempted this? I peeled back the wheel well plastic, pushed the plastic bumper out as far as I could but I can't get access to the bulb. I can barely touch the unit. I looks like I might get access from underneath, coming up from the bottom. I would have to put the car on jacks or ramps, haven't tried this yet.
As it is, there is a "bunch of stuff" that blocks getting the light casing if I attempt to get it in a traditional approach. It looks like you would get access by removing the headlamp and coming in the from the top.
This is the drivers side.
Thanks.
Old Feb 20, 2022 | 11:38 AM
konigstiger's Avatar
'71 Pinto
Have you tried opening lens, tape surrounding area and use plastic wedge to release forward catch. Replacement: 194 wedge base 5W bulb, part # 000000008154 (cross reference for aftermarket).
Old Feb 20, 2022 | 01:35 PM
Tbbt CLS's Avatar
2013 CLS550 4Matic OE Tuned
They are a real b*tch to change. Expect scraped hand or wear gloves. While you're goingto all this trouble, why not change them to clear lens LED markers. Check eBay for them.
