Issues on my C218 2012 CLS350 after windows tinted
Old Apr 15, 2022 | 09:16 PM
super-ss's Avatar
CLS350 W218
Red face Issues on my C218 2012 CLS350 after windows tinted
Hello Guys,
I faced those issues after titned my car windows. The issues are:
  1. No reverse lights
  2. Camera not working
  3. No Signal rear lights
  4. Trunk release not working
  5. Fuel level gauge not working
  6. Diffeuser light always on
  7. Light switch not working and all lights are on once I open ignition
  8. etc
I checked all fuses, AUX battery and everything is working fine. Please I need your kind support to fix those issues.
Error codes:
  • U011100
  • U011187
  • U014600
  • 474F00
  • A3A813
  • U014200
  • U14287
  • 510808
Thanks in advance.
Regards,
Old Apr 30, 2022 | 12:59 PM
rick hesek's Avatar
2014 CLS550
Very unusual.
Did you remove the door internal trim panels to do the tinting?
Perhaps something was not reconnected?
Old Apr 30, 2022 | 10:58 PM
kemofei's Avatar
2012 CLS 550
This doesn't really make sense, tinting the windows should NOT do that lol.
As rick said, did you remove any door panels or anything electrical or mess with anything like that?
Perhaps some of the water from the tinting process (or whatever liquid it is) seeped into the door panels and messed up some of the electronics. If that's the case, it's gonna be an expensive fix. Hope you can get the tint shop to accept liability if that ends up being your issue.
Old May 1, 2022 | 01:15 AM
DigitalDisaster's Avatar
2013 Weistec 540/715 tuned CLS 550, 2008 E350, and '07 Jaguar S-Type R
I'm betting it's a low voltage issue since they likely had the doors open for a while. Many modern cars are very sensitive to voltage - my wife's Jag accessories start going haywire at anything below 12. 3volts. The battery tests fine but needs to be replaced.
