CLS550 Brake Pads and Rotors
Old Sep 19, 2022 | 11:54 AM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Hi all,
I'm looking for Zimmerman coated rotors and akebono pads for front brakes of cls550. I'm having trouble finding the appropriate ones. Does anyone know the part number from those brands that works?
I have this same combo on my w204 and it's extremely low brake dust.
Thanks!
Old Sep 20, 2022 | 12:01 PM
konigstiger's Avatar
'71 Pinto
Here are MB part #s. Enter part # 0074205820 for pads, “disk” for rotors (0004211812 not found) here: https://www.fcpeuro.com/Mercedes~Benz-parts/ will pull compatible aftermarket brands.
Old Sep 20, 2022 | 03:01 PM
Adi-Benz's Avatar
Thanks, tried FCP but they don't sell zimmerman or akebono for them.
I guess I'm not sure if they even make them...
Any recommended brands other than OEM? Looking for ceramic pads.
Old Sep 20, 2022 | 03:13 PM
'71 Pinto
2015 CLS400 4matic:
MB part # 0074205820 - https://www.fcpeuro.com/Mercedes~Ben...rds=0074205820
"Disk" search - https://www.fcpeuro.com/Mercedes~Ben...&keywords=disk
Old Sep 20, 2022 | 03:20 PM
Adi-Benz's Avatar
Ah, should have clarified. Upgrading with 550 calipers.
I found Zimmerman rotors for the E550. Dimensions are the same so there should be no difference....?
360x36mm EDIT: Offset is different.
https://www.fcpeuro.com/products/mer...man-0004212012
I found ceramic brembo pads, fitment confirmed on brembo website (out of stock), only place I see them available for now is this website...
Maybe sketch? Not sure...
EDIT: Found them on amazon/ebay. Part number for ceramics: P50098N part number for standard: P50098
Small caliper discussion: https://mbworld.org/forums/e-class-c...new-550-a.html
EDIT AGAIN: These rotors are same size as w204 c63...which makes me wonder if I can put 550 calipers/setup on my c300...definitely not necessary for that car though, has great brakes...
Old Oct 5, 2022 | 08:20 PM
Adi-Benz's Avatar
Looks like the center of the rotor is too "deep" thus preventing the caliper from sliding in between the rotor and the support bracket (from which 2 bolts are placed.)
I see people on E350's adding these all the time without this issue - what could be wrong?
Old Oct 5, 2022 | 09:14 PM
Adi-Benz's Avatar
Looks like 10mm offset difference with E class vs CLS rotors.
Old Oct 6, 2022 | 04:11 PM
Adi-Benz's Avatar
To follow up, since everyone that has done this upgrade has an E class (since this is not necessarily a prevalent ugprade with the W218 due to majority being 550's) the E-class front rotors have different offsets as shown here
by another individual from the E class section.
13/'14 E550, 360mm 64.5mm offset rotor.
'13 CLS550, 360mm, 51.4mm offset rotor.
So if you have a CLS, you must get the CLS550 brake rotors, and vice versa for E class. Otherwise, you won't be able to fit the caliper due to the offset.
You can also use the part number to buy the rotor.
Old Oct 10, 2022 | 02:08 PM
Adi-Benz's Avatar
Process shots and completion......
Old May 13, 2023 | 08:46 AM
Simuri's Avatar
CLS550 4matic
Any idea what the torque value is for two 18mm bolts that hold the caliper to the steering knuckle? Getting mixed messages from 115 nm to 180 nm. Much appreciated. Thanks
