Another one bites the dust... probably
I was driving when suddenly I lacked power and immediately stopped on the side of the road, engine turned off or stalled.
After that, impossible to start her up again, it appears that the starter wants to turn the engine but can't, then a message appears on the dash with "ECS and ABS inoperative".
I didn't see any oil on the ground nor any other sign of catastrophic failure but these symptoms makes me think seized engine.
She left on a tow truck and I'm now waiting on news of the garage if they find something obvious.
If you have any idea on what could be an issue with those symptoms, I'm all ears.
Cheers
i'll see if I can get pictures of the filter but the MB dealership who did the diagnostic for the car supposes something blocked the oil intake and lack of lubrication lead to the engine seizing and now they can't turn it in either direction.
I'll keep the thread updated if I can get picture and news but the car needs a new engine and that'll probably be more than the car is worth. I regret it because it was a very pleasant car but it'll be my last M278, maybe even my last MB depending on the legal case that I'm about to open with the last garage that worked on it.
As I said, I'll put pictures if I can but I think I'm now in months, maybe years of legal proceedings.
below is the picture of the "collapsed" filter that has some forbidden glitter in it. We don't exactly know what killed the engine but it was definitely related to oil starvation.
Borescoped 3 cylinders, one was TDC so nothing of value was seen, for the other two, one had a slight amount of marks but nothing worrysome, the other one had scratches all around but looked like it was really light. So no catastrophic/impressive damage in there.
However the oil felt really bad, bad smell, very brownish color so we sent it to oil analysis. I didn't get the full report due to local procedures but a sum up was "contaminated by cooling liquid, high water content (>0.2%), high sodium content (>200ppm), confirmed glycol in oil, abnormal silicon content (>100ppm) (possible rtv contamination)." But its viscosity was seen as normal.
I'm currently in legal procedures for that car and it'll be months or years before I see the end of it. It's a shame because it's a great and very enjoyable car that I wish I could have had for a decade at least. I'll see where this takes me but needing a good car for travel, I have gone for a E550 Wagon that came originally from Japan, it's the same chassis so I feel at home in there and really hope that M273 will reach very very high mileage.
Hopefully it turns out to be something easy (hey, there is a chance...).
I'm a bit gutted that it appears to be something very peculiar that was diagnosed too late or that the last repair wasn't done extensively enough (more inspections should tell us more).
The engine is an M278 (4.6L twin turbo) known for many failures but not really that one.
I'm not hopeful on getting the car back and to tell the truth, I'm not sure I want it back at that point. If they repair it, it'll be some major changes, dropping the value and not really improving my confidence in that engine. So within the legal proceedings, it's very likely that I'll trade the car back in. Plus I already have a replacement with my E Class and the more reliable 5.5L M273. But I'll sure regret many things (NTG4.5 COMAND, ventilated and massaging seats, nicer wheel and dashboard imo).
Thanks, I'll be there for a while probably, let's hope it gets in my favor quickly so I can come to an arrangement soon enough.
The M273 is more robust according to what I've seen, especially late production models when the balance shaft gear issue was resolved.
What kind of issues did you get on yours ?
I'm not suing at random, it's the follow up of event that lead the jurists, my lawyer and I to go that way. Plus the oil analysis concurs with the coolant leak to oil not being fixed properly so still under the obligation for seller to fix it.
Edit: forgot to say I bought it from a professional which makes this procedure possible.
