CLS Coupe (C219) Discuss the CLS Coupe.
HID foglamp help
Old Sep 20, 2006 | 01:44 PM
SSM AMG's Avatar
2004 S55 AMG
HID foglamp help
Can someone tell me the bulb size for the factory foglamps? Also if there is a shield on the bulb or is it open? I am trying to order some HID's for a friend of mine for his cls. If any of you guys can post some pictures of your car if you have HID fogs that would also help. Thanks.
Old Sep 20, 2006 | 04:45 PM
glennp_1999's Avatar
09 E350 Black 06 CLS500 Alabaster White
H11 for the for and no there is no cover. Straight up install should take about an hour to do bought sides. Should the lights flicker after the install then it needs to be reprogammed. Follow the link below I did a write up on it for the install.
http://www.benzworld.org/forums/w219...og-lights.html
Old Sep 21, 2006 | 10:26 AM
SSM AMG's Avatar
2004 S55 AMG
Thanks. One more question. Is there any glare from the HIDs?
Old Sep 21, 2006 | 12:04 PM
What glare are you referring too? Light scatter?
Old Sep 21, 2006 | 08:54 PM
SSM AMG's Avatar
2004 S55 AMG
Yes because with alot of open housing, the light goes everywhere.
Old Sep 22, 2006 | 03:07 AM
Light scatters if the kelvin rating of the bulb is to high. My advice to avoid light scatter is to go with 4300K this is the brightest HID setup you can get. The light doesn't scatter all over the place. Anything above 6000K is overkill, light will not be concentrated it starts to scatter all over the place. Don't get bulbs that has the blue hue cus it doesn't do squat for you. Bright to look at but almost no light projection in front of the car when driving at night. I use to have 7500k on my other car took it off the next day cus my stock setup was projecting more light. If your friend wants to do the headlights it takes an H7 and get the 6000K rating bulb. The effect of these combo is unreal it's like daylight when driving at night. Goodluck with the mods chief keep us posted.
Old Sep 22, 2006 | 02:26 PM
SSM AMG's Avatar
2004 S55 AMG
Thanks for the info. I will try to post some pictures when I am done.
