CLS Coupe (C219) Discuss the CLS Coupe.
Help with V1 install
Old Dec 27, 2006 | 03:31 PM
jir591's Avatar
I was installing my V1 in my new CLS and trying to pull power from the fuse box on the drivers side. Are any of these fuses switched on with the ignition?
Old Dec 27, 2006 | 08:28 PM
weeeza's Avatar
I had the same problem and then we hooked it up via the brakes, my stereo guy did it so I don't know exactly how it was done but I know he used the wire behind the brake lever because we could not find any other fuse that shuts off with ignition, works great now
Old Mar 7, 2012 | 02:55 PM
Jksellman's Avatar
'03CLK500,13 Panamera GTS,00 BOXSTER,96CARRERA CAB
weeeza...parking brake or driving brake??
Old Mar 7, 2012 | 03:53 PM
Benzy550's Avatar
2011 ML550
You need a savvy from v1, check v1website
Old Mar 7, 2012 | 06:31 PM
Jksellman's Avatar
WOW SAVVY!
The Savvy must be a new item...new to me anyway...but a great idea and solution.
I have hardwired the V1 in my other cars, but the CLS is not that easy.
I ordered the Savvy today.
Thanks alot for the tip.
Old Mar 13, 2012 | 06:43 PM
click430's Avatar
12 CLS 550, 65 Shelby 427 SC, 03 GMC Envoy
My installer went to the box under the hood, through the firewall grommet. He found a source that is switched, and does the "decay to off" after the car is shut down.
Old Mar 13, 2012 | 08:19 PM
Jksellman's Avatar
Valentine Savvy seems like the best solution..
I'll report back when it arrives and I install it....
Old Mar 25, 2012 | 06:35 PM
Jksellman's Avatar
V1 & Savvy installed.....
The install went fine and the Savvy works as advertised (I may go back and retro-fit in my other cars).
A few notes on the design:
I think Valentine could have done a lot better on the physical design.
It should be shallow, as to avoid kicking it as most OBDII ports are in the footwell.
It should have the two RJ jacks in the unit, not on a 6" cord with a "dongle".
It's a bit awkward to get it all out of the way.
The benefits outweigh these minor issues,,,,,
Old Mar 26, 2012 | 09:08 PM
Benzy550's Avatar
2011 ML550
I agree with you, may be next version will be.
I kicked the savvy sometime
