CLS Coupe (C219) Discuss the CLS Coupe.
Has anyone installed aftermarket Amp with Subs on the CLS?
Old Apr 24, 2011 | 01:02 AM
JS-CLS550's Avatar
CLS550
Has anyone installed after market amplifier along with Sub Woofer in the trunk of their CLS?
Old Apr 24, 2011 | 07:08 PM
JS-CLS550's Avatar
CLS550
I guess I gonna be the first one to try!!! Should be pretty simple since the battery on MB is in the rear. The only thing I have to figure out is the remote wire to turn the amp on and off.
Old Apr 24, 2011 | 09:47 PM
mike219's Avatar
2006 CLS500
I installed two 12" Rockford Fosgate p3 subs with a fosgate amplifier, and although it was running well for the most part, sometimes the subs wouldn't work out of nowhere until they eventually just blew out. Got it done at Pacific Stereo (NOT recommended) and now have a sound system that makes no sound. Be careful and if you choose to do it, do it right!
Old Apr 25, 2011 | 01:23 AM
JS-CLS550's Avatar
CLS550
I am thinking of installing one 12" sub woofer. I have an old JL W6 3 ohm dvc subs sitting in my garage that I use to use along with Phoenix Gold and PPI amp. I just need to figure out how to connect remote wire.
I installed amps before so have a pretty good idea how to install them the only problem is remote wire as I mentioned.
Old Apr 27, 2011 | 10:56 PM
nJuDunno's Avatar
The remote wire should be pretty simple, there is a fuse panel on the left side of the trunk next to the DVD drive. Just find a fuse that gets power when the ignition is on using a tester.
Old Apr 28, 2011 | 11:38 AM
UDWANIT2's Avatar
2016 E550 Cab & 2011 GL 550 & 09 VROD Muscle & 06 Seadoo Speedster LE .......
1 JL 12 W6 wont make much difference unless u cut the ski bag area / rear Arm rest....n dis assemble the rear factory sub woofer...
i wanna run a 12 W7 with 1000/1 i have everything jus contemplating should i .......the woofer n amp r so heavy the custom box setup will be more heavy......
u need minium 2 12 W6.....will hit clean..
Old Apr 28, 2011 | 08:19 PM
JS-CLS550's Avatar
CLS550
One of the main reason why I want to install just 1 sub is because of the weight of the woofer and the box. I don't want subs sinking my car in the rear with all that weight.
Old Apr 30, 2011 | 09:29 AM
UDWANIT2's Avatar
same reason im waiting........
Old May 2, 2011 | 11:43 PM
whazzzzuup's Avatar
Lexus GS400
https://mbworld.org/forums/cls-coupe...urs-total.html
Old May 3, 2011 | 01:20 AM
JS-CLS550's Avatar
CLS550
I actually saw the theas.
How does it sound? Any issues with warning light due to voltage drooping when Bass hits?
Old May 3, 2011 | 09:30 AM
UDWANIT2's Avatar
you gotta have a capp......so there is no drop in voltage....
Old May 3, 2011 | 12:58 PM
whazzzzuup's Avatar
Lexus GS400
There has been absolutely no issues. I have never used a cap in any if my cars. I just make sure the alternator and battery are good before I hook my audio systems up. And ive had countless systems and put them in countless cars. The quality and complexity of the system does matter too. The most complicated system I've run was only a 3 amp system in one of my old cars. Modern high quality amplifiers have strong caps built in. But an external capacitor wouldn't hurt.
Old May 3, 2011 | 09:38 PM
JS-CLS550's Avatar
CLS550
You guys think one 12" sub would have decent bass? As I mentioned, I don't want to sag my rears due to sub woofer weight.
Old Aug 6, 2011 | 06:56 AM
kl4z's Avatar
w211 200Komp
OOOppss! old post.
Be careful because CLS got SPC brakes with a spec own backup battery thats supported via the main battery!
// Klas
Old Aug 6, 2011 | 11:59 AM
UDWANIT2's Avatar
Jus ordered 1 12 W7.................n 1000/1 ...........and a Oddyssey Cap.......
Now on a mission to find a Custom installed........if i were u i would only go with JL or Kicker 1 12 top of the line model there best one from any one of these company n it will hit hard.......
Old Jun 25, 2012 | 07:33 PM
freemanjc's Avatar
CLS 550
Smile
Did you ever get your sub hooked up?
Old Jun 27, 2012 | 02:34 PM
M1RAG3's Avatar
CLS550 AMG Pkg.
I am going to take out the CLS floorboard (covers the spare tire etc..) and custom cut a piece of plywood to fit over the floorboard. Essentially the plywood will fit over the OEM floorboard, but will be wide enought that it is supported by the metal on the sides of the trunk floor (i.e. beside the spare tire hole). I did this with my Maxima, and it worked great for my 2 x Alpine Type Rs, 1000 / 2 amp, and cap. No way that OEM CLS floorboard is going to support 2 x 12s + amp, probably 80+ lbs in total.
Old Jun 28, 2012 | 06:41 AM
dirtydog's Avatar
2006 CLS500
This is what I did for the amp mount. Totally hidden and no heat issues.
I installed a 12" Kicker Solobaric box and have all the bass I could ever need.
Old Jun 28, 2012 | 09:38 PM
freemanjc's Avatar
CLS 550
Hook us up
Can you please elaborate further on your set up. Where you tapped into to get a speaker signal, ground locations, remote location and what RMS rating you ramp is? Spill the beans here and give is a little more infor for us guys who want to do the same. Did you use a line out converter? I am thinking os using an old Audio Control LC6i! Hook us up!!!!!!!!!
Old Jun 28, 2012 | 09:58 PM
dirtydog's Avatar
2006 CLS500
I taped directly into the rear sub. No line converter.
The AMP is a single channel Kicker Z750 750x1
I got most of my info from this post
http://www.benzworld.org/forums/w219...l-4-hours.html
Big thanks to whazzzzuup for taking the time to writeup his original post.
Good Luck!
Old Jun 29, 2012 | 10:44 AM
freemanjc's Avatar
CLS 550
Good Luck!
Thanks,
But I don't understand how to hook up an RCA plug to those wires (without a line output converter)?
Old Sep 6, 2014 | 01:30 PM
Marcus adams's Avatar
2006 cl 500
Do like I did, run a whole new complete system and bypass everything factory so that you can put everything back when selling.
Old Sep 6, 2014 | 01:33 PM
2006 cl 500
I have. You should remove the rear factory sub first.
Old Sep 6, 2014 | 01:35 PM
2006 cl 500
Do not do that. Purchase a Rockford fosgate 360.2
Old Sep 6, 2014 | 01:38 PM
2006 cl 500
Get a 12w7 or 13 w7 jl audio sub. Use a enclosure with a 32hz tuned port.
