Got 6k LEDs for my Front Parking Lamps - DIY Install?
I ordered the AZNOPTICS 5k, LED versions.
Thx in advance.
Called him and left a message w/ no response. I found another reputable installer in Ajax, will see how it goes.
I ordered the AZN Optics parking lights + license plate festoons. The plate lights are INSANELY bright and are truly pure white...sick. They are actually brighter than those Lexuses with the CCFL plate lights.
The 2 top screws on the headlights are easy enough to remove. I read that there is a 3rd screw that is only accessed by removing the bumper....so I gave up and I'm going to get a pro to do it before I F something up lol.
i just replaced my front parking light the other day because it was burnt out. It was easy to do, took me less than 5 minutes to change one.
1) Open hood
2) Remove plastic intake tube
3) Remove Plastic cap for high beam and parking light bulb.
4) At this point you cannot even see parking light bulb, Dont panic, twist highbeam bulb (Top Bulb) and pull it out. Leave it attached to wire and move it out of the way.
5) Now you will see parking bulb, do not pull on the wire, grab the housing with your thumb and index finger, everything is feel from here on out, you wont be able to see anything, twist the housing left and right to free it from the housing. So it is still in there but a little looser
6) reposition yourself and grab the housing again but now vibrate it up and down and pull back at the same time, took me like 10-15 wiggles but it eventually moved.
7) once the bulb and housing is out, put the other bulb in, test it before putting it back in to see if it works. Slide it back in by minor pressure on back ot the housing.
8)Put high beam back in, cannot see much here but push in and rotate at the same time, you will feel it click solidly in place.
9) Put cap back on, put on the intake and you should be ok.
Since i only had to replace drivers side i cannot say much about passenger but i am guessing it shoul dbe same, if anything the other side looked easier and less cluttered. HTH
thx for taking the time to write the DIY...I will try this tonight.
1) Open hood
There are a few things I want to add;
1) "At this point you cannot even see parking light bulb, Dont panic, twist highbeam bulb (Top Bulb) and pull it out. Leave it attached to wire and move it out of the way:" >> This is the key enabler of this whole install, getting that bulb out of the way.
2) It is extremely difficult to get your fingers on the plug holds the parking light, SLOWY snake your hand behind the headlight housing and take your time to try snaking it in from different angles until you are comfortable that you can get your fingers onto the parking light plug.
3) You will likely get small cuts while attempting this procedure unless you go very slowly.
4) The parking light plug does NOT need to be turned counterclockwise or clockwise to be removed from the headlight housing. You need to get a good grip on the plug and jiggle it WHILE pulling it straight back out. It is the PULLING motion that removes the parking light housing, NOT ANY KIND OF TURNING MOTION since the housing is a SNAP-IN style housing not a rotational one.
5) After you swap in your new bulb, push the parking light plug back in until you hear an audible CLICK.
Hope this helps out some others on here.
Side Note: The AZN OPTICS 5K parking light is NOT and I repeat NOT a match for the CLS HID headlights. The bulb is too white and needs more of a blue tint. I will be ordering a new set of 8K bulbs to replace my 5K ones.
I want to see pics of the 8k in a CLS housing, I'll post pics of mine this weekend, been too swamped at work
Read more: https://mbworld.org/forums/cls-coupe...#ixzz2sAWCIqKa
Surely there must be an easier way to do this?
I have attached some pictures for others if anyone gets stuck
If you have big hands it might be easier to get some long handled, angled, needle nose pliers in there.
John
