CLS Coupe (C219) Discuss the CLS Coupe.
2006 cls500 rotor replacement
Old Oct 5, 2012 | 02:33 PM
mrwhitecls's Avatar
(2) CLS 500
Has anyone changed their rotors on their cls500? Is it pretty much standard as any other car besides the sbc?
Is disabling it the same way as you would when changing the pads all that needs to be done to be able to safely remove the rotor?
I've searched everywhere but no one has posted about swapping their rotors out. Thanks in advanced!
Old Oct 5, 2012 | 03:21 PM
GuestFromTampa's Avatar
W212 E250 BT 4M
How do you disable SBC ?
i always tought you just disconnect the battery in the trunk and it will do the trick...
Old Oct 5, 2012 | 03:56 PM
mrwhitecls's Avatar
(2) CLS 500
I've read that people disconnected it a few different ways one being from under the hood. So I'm wondering if disconnecting the sbc will allow me to remove the caliper with no problems.
Old Oct 6, 2012 | 07:53 AM
dirtydog's Avatar
2006 CLS500
I swapped out my pads and rotors for drilled rotors and ceramic pads last winter. I disconnected the SBC Module under the hood and reconnected it when done. I made sure I left the key out of the car also. When I was done I reconnected the module then pumped the brake pedal to push the caliper pistons back out to seat the brake pads. After that I started the car and had alot of flashing lights on the dash and could hear the pump for the SBC running. I may have has to reset itself in my case because I compressed the caliper pistons back in for the pad swap. After pumping the pedal some more and a couple more ignition cycles everything was back to normal. Hope this helps and good luck.
Old Oct 6, 2012 | 10:18 AM
mrwhitecls's Avatar
(2) CLS 500
Thanks dirty dog! Did you open the reservoir prior to compressing the pistons?
Old Oct 6, 2012 | 12:25 PM
dirtydog's Avatar
2006 CLS500
I believe so. Cant remember if I cracked the bleed wihile compressing the piston or not.
Old Oct 6, 2012 | 12:47 PM
W212 E250 BT 4M
how exactly you disconnected the SBC Module ?
i am planning to install new rotors and pads next weekend.
Old Oct 6, 2012 | 01:53 PM
dirtydog's Avatar
2006 CLS500
There is a big black plug on it. Turn the ignition off and remove the key. Unplug the modules main harness and you should be fine. As with any car with ABS you should always be aware that you could be seriously injured if somehow the brakes activate while working on them. Thats why its a really good idea to disable the system while servicing them. Different automakers have different procedures for working around these systems and I do not know what MBs is but unplugging the module worked for me.
Old Oct 6, 2012 | 02:08 PM
clsjack's Avatar
08' SL55 amg
How's this for complicated ?
http://www.lados.ru/lados/lados.nsf/...0DIAGNOSIS.pdf
Old Oct 6, 2012 | 04:15 PM
dirtydog's Avatar
2006 CLS500
Wow. Nope, didn't do all that.
Old Oct 6, 2012 | 04:44 PM
boschk's Avatar
2006 CLS500 - Iridium Silver w/ AMG Sportline
Originally Posted by clsjack
The engineer that invented this proceedure should be shot.
Old Oct 6, 2012 | 06:17 PM
mrwhitecls's Avatar
(2) CLS 500
Just wanted to return back with my outcome and boom. Easy. I did what dirty dog said and just unplugged the wire from the sbc module under the hood. To unplug you just pull up on the little handle thing, as you continue to keep pulling it upwards the whole plug starts to shift away and unplugs itself. To be over protective I left my keys far away along with the windows rolled down and allowed no one around my car (even though sbc was disconnected, better safe than sorry). Thanks dirty dog.
Didn't have any lights come up or anything just pumped brakes and listened. i'm fixing to take it around the block just to be sure all is well.
**Also wanted to go on the record and say I am not a mechanic in any aspect nor am I trying to be one. I did this at MY OWN risk and don't recommend this to anyone, esp if you don't know what you're doing.**
Old Oct 6, 2012 | 06:26 PM
boschk's Avatar
Originally Posted by mrwhitecls
Just wanted to return back with my outcome and boom. Easy. I did what dirty dog said and just unplugged the wire from the sbc module under the hood. To unplug you just pull up on the little handle thing, as you continue to keep pulling it upwards the whole plug starts to shift away and unplug itself. To be over protective I left my keys far away along with the windows rolled down and allowed no one around my car (even though sbc was disconnected, better safe than sorry). Thanks dirty dog.
Post pics if it doesn't.
Old Oct 6, 2012 | 09:10 PM
dirtydog's Avatar
2006 CLS500
Glad it work out for you man.
Old Oct 11, 2012 | 10:32 AM
W212 E250 BT 4M
How many brake pad sensors CLS have 2 or 4 ?
Old Oct 11, 2012 | 05:51 PM
jaedee's Avatar
w205 C63s, w212 E63,w219CLS500-SOLD! w211 E63, 2006 E60 M5 (KABOOM!)
1 front and 1 rear.
Old Oct 11, 2012 | 08:30 PM
W212 E250 BT 4M
Originally Posted by jaedee
1 front and 1 rear.
Thank you !
Old Oct 13, 2012 | 04:33 PM
W212 E250 BT 4M
1 front and 1 rear.
Wrong !
2 front and 1 rear,also Front Left and Front Right sensors are different...
Front Right and Rear are the same
