CLS Coupe (C219) Discuss the CLS Coupe.
CLS 320cdi problem with number plate lamp
Old Dec 3, 2013 | 08:21 AM
madisvaltu's Avatar
Mercedes-Benz CLS 320cdi
Hello,
I have problem with my 06 mb cls 320cdi. Left-hand number plate lamp isnt working. It keeps blinking after 5 seconds..I have changed the lamp but the fault is still there. I changed a couple mounths ago and but there LED-s.
When i took both lamps out suddenly left-hand lamp work and the other, right-hand lamp kept blinking. LED´s worked correctly before..2 weeks.
Any suggentions? Do i need to replace the SAM module or is there anything to check?
Greetings from Estonia,
Old Dec 3, 2013 | 08:49 AM
GuestFromTampa's Avatar
W212 E250 BT 4M
SO now both licence plate lights are LEDs right ? If so did you replace just an LED bulb or the whole light assembly ? Look at the pictures.
Do you have any other lights on your CLS replaced with LED ?
Do you have this
or this
Old Dec 3, 2013 | 09:08 AM
madisvaltu's Avatar
exactly the firsts..I changed the bulbs. front park lamps are also LED and they work correclty.
Old Dec 3, 2013 | 09:27 AM
W212 E250 BT 4M
Problem solved then, you have too many cheap LEDs ive had exact same problem .so you really have 2 option -replace park lamps with quality LEDs like these http://www.aznoptics.com/index.php?m...&products_id=8 or i am selling a pair becouse i didnt like it https://mbworld.org/forums/mobile-el...ptics-com.html
or option two will be purchasing quality LED licence plate lights like picture #2 , they are not that expensive , i think i paid $40 or so...
Old Dec 3, 2013 | 09:36 AM
madisvaltu's Avatar
But over 2 weeks both leds (front and rear) worked correctly...who to explain this? Today i tried another new leds to the licence plate number and they didnt work too..
Old Dec 3, 2013 | 09:53 AM
W212 E250 BT 4M
I think it is car ECU adapting or something because LEDs drawing less power then regular light bulbs...
I am just sharing my own experiance-ive had same problem and i found solution that worked for me
Old Dec 3, 2013 | 10:03 AM
madisvaltu's Avatar
Ok, i will try ugly yellow lamps and will write, if it helped or not.
Old Dec 3, 2013 | 10:27 AM
W212 E250 BT 4M
It wont be instant, ECU will have to adapt again. Now Yellow Lamp you said are we taling about the turn signal or parking light ?
Perhaps i am wrong but i tought
Old Dec 3, 2013 | 08:53 PM
madisvaltu's Avatar
I changed licence number plate lamps back to original lamps. it worked! Thank you alot GuestFromTampa!
Old Dec 3, 2013 | 10:39 PM
W212 E250 BT 4M
No problem i am glad i was able to help. Just Pay $34 and get a real licence plate LED lamps that wont cause you any problems
http://store.ijdmtoy.com/Mercedes-CL...t-p/led-s2.htm
Old Dec 5, 2013 | 04:54 PM
Ben1127's Avatar
Cls 320cdi w219
I bought these
But can not the old ones out cos the chrome trim on the boot lid is stopping them from coming out
What a stupid idea, why not made the gap slightly bigger, and to take the chrome trim off is impossible cos it's stuck on!!
Old Dec 5, 2013 | 06:07 PM
W212 E250 BT 4M
Unfortunately this is the part that ***** from IJDMTOY.com dont tell you and then they deleted my review even tough i re-left it 5 times .
Anyways it just takes longer , you will need to remove 2 screws and then there is a double sided tape that holds boot lid in place. I used old credit card to separate the lid from the trunk. Taking off old tape off the plastic lid that is a real PITA. Took me like an hour. Then you have to use new doublesided tape, i used 3M . Not that hard.
this is what it looks like when you done
Attached Thumbnails CLS 320cdi problem with number plate lamp-dfghjhj-1-.jpg   CLS 320cdi problem with number plate lamp-dfghjhj-2-.jpg
Old Dec 5, 2013 | 06:17 PM
Ben1127's Avatar
Cls 320cdi w219
We're u happy with them once u managed to fit them, hope they are not too bright, thanks for ur help
