CLS Coupe (C219) Discuss the CLS Coupe.
Wheel Speed Sensor Gap Issue
Old Oct 2, 2017 | 09:10 PM
bcameron's Avatar
2007 CLS 550
Hi, I had the infamous issue where my ABS system lit up like a Christmas tree, my cruise control stopped working, the steering got hard and noisy, etc. while on a long trip earlier this summer. I took it into to a Mercedes-Benz dealership and they diagnosed the problem as a left rear wheel speed sensor issue. I have a noisy wheel but they said the bearings seem fine and say it's my tires. Anyway, I ordered one of those sensors and a great little device to read the codes for myself (iCarsoft i980). I replaced the sensor and then cleared all the codes. I then put about 2000 miles on the car before it threw the codes again. This time is says "L6/3 (left rear speed sensor): Inspect distance from rotor to sensor". When I read the information coming from it in real time, it occasionally says the gap is NOT OKAY. It's not clear to me how to fix this. I pulled the sensor again and there aren't any shims or anything and I blew out the hole while rotating the wheel to see if it made any difference - it doesn't. Could this be a bad wheel bearing? How can you adjust this gap? Thanks.
Old Oct 3, 2017 | 11:30 AM
konigstiger's Avatar
'71 Pinto
See here: https://mbworld.org/forums/e-class-w...-bearings.html
Old Oct 3, 2017 | 11:47 AM
bcameron's Avatar
2007 CLS 550
I'd searched all over and hadn't seen that thread. Sounds very much like it might well be an issue with the bearing seal (which I didn't touch but perhaps it's rusted out). I'll order up a new bearing/seal and see if it works. Thanks!!!
