CLS Coupe (C257) Discuss the CLS Coupe
Driver window won't open
Old Apr 28, 2024 | 08:55 AM
captj3's Avatar
2019 CLS450 4 Matic 2011 E550
My drivers side window will not open. It will drop a 1/4" when you open the door. This happened once before and the dealer fix it under warranty. The car no longer has a warranty. Any suggestions to reset it? That was what the dealer did.
Old May 4, 2024 | 08:19 PM
W205C43PFL's Avatar
You can try synchronizing it...
First close all doors then have accessory mode on then close the windows. Once it stops release and then pull the switch up like you normally CLOSE the windows for 5 second, make sure to pull it beyond resistance (in other words if you have not noticed already if you slightly pull it and then you pull it harder there is a click, that is called beyond resistance). Then try OPENING the windows by pushing down and beyond resistance and try holding it for 5 seconds as well.
Old May 5, 2024 | 02:21 PM
captj3's Avatar
Thanks for the reply and procedure. I tried that before posting. It turned out I had to bring it to the dealer they reset the window through the OBD port. For some reason the windows lost its memory. This happened once before. 2 dealers neither new why it happened. I was wondering if a product like (Carly) would be able to fix it or something like it.
. Nonetheless thanks for the help.
Old May 5, 2024 | 06:27 PM
W205C43PFL's Avatar
Sorry that I wasn't helpful, I wonder if there is a software update that can be performed to fix the auto memory loss issue?
Old May 6, 2024 | 07:36 PM
captj3's Avatar
I dint know. I'm hoping koniggsing (sp) chimes in he may know. He's pretty knowledgeable with all models.
Old May 6, 2024 | 07:38 PM
W205C43PFL's Avatar
If u have a friend or shop that has XENTRY they might be able to update the module responsible for cheaper than a dealership would.
Old May 6, 2024 | 07:46 PM
captj3's Avatar
I wish I had a indy here instead of the dealership. I just changed dealers after the last shorted me 2qts of oil the last time i had them change it. The old one told me I had to wait 1 month for a appointment with a loaner. Needless to say I went to MB across from my BMW dealership they did my service and window the next day, only because I didn't have the car with me.
Old May 6, 2024 | 07:52 PM
W205C43PFL's Avatar
Sorry to hear that : ( FWIW, overfilling engine oil is common in some places as well, which in some cases is worse than underfilled oil because overfilling creates foam. I just hope in your case, the underfilled 2 quarts wasn't below the min line.
Old May 6, 2024 | 08:33 PM
captj3's Avatar
it was okawathe light came on when I pulled into my garage. They delivered oul to me after i called them and *****ed about it. They also didnt like the survey i left them. I got a wheel alignment and complete detail out of them. I didn't get a chance to correct it as I was waiting for the work to be completed before doing so. They closed it out before hand. Dumbasses.
Old May 6, 2024 | 08:38 PM
W205C43PFL's Avatar
Yikes, hopefully that was just a one time thing, reviews certainly has weight and a good way to get them to cooperate.
