Any pictures of the roll cage of AMG GTR with AMG Track Package
Old Oct 3, 2018 | 11:01 AM
thebishman's Avatar
‘24 BMW iX M60
Interesting. Can U please ask your customer to have detailed pix taken of the install process?
TIA
Old Oct 3, 2018 | 11:16 AM
MG1422's Avatar
GTR
TIA
It should be delivered next week. Sadly, my car does not arrive until late November but it will be this set up.
Old Oct 3, 2018 | 11:26 AM
WhiteBlack's Avatar
fun ones.
Those seats are not designed to be used with harnesses. That’s a really dangerous setup.
Old Oct 3, 2018 | 12:17 PM
MG1422's Avatar
GTR
Can you please elaborate on why its dangerous?
Old Oct 3, 2018 | 12:29 PM
WhiteBlack's Avatar
fun ones.
It’s specifically referenced in the eu manual that they’re not designed for harnesses.
ideally you need individual slots for each strap. The folding mechanism is unlikely to be designed for the additional loads. In an accident with an inertia reel belt you’re supposed to move forward from the seat to absorb the energy and prevent submarining so the seat back does really have any significant load placed on it. Harnesses are the complete opposite.
as I said in the posts above even with the eu spec buckets it’s a very poor setup esp for taller drivers.
The scroth 4 points mount really poorly with the stock cage.
Old Oct 3, 2018 | 07:41 PM
thebishman's Avatar
‘24 BMW iX M60
I can see two problems: the angle of the shoulder belts will be far off to be safe, and the headrest cushion looks like it might make wearing a HANS type device difficult. Hope I’m wrong on both.
Bish
Old Oct 4, 2018 | 03:12 PM
  #32
MG1422's Avatar
GTR
I know that ideally you would need slots for all straps but this is how it is done with all corvette competition seats for the lap belts, same with Ferrari, Nissan gtr, Porsche with sparco spx seats etc. As for preventing submarining, with a Schroth Racing Profi II ASM your body will absorb the energy thanks to the shoulder straps with ASM technology.
Bish, for the angle I see no real problem at least for someone my height 5'10. My shoulders come right below the slots on the seat. And for the angle the seat can be moved to have it any wear from 0-20 degrees. From what it looks like in the picture it looks very doable to get the correct/safe angle.
As for the HANS you might be right, I won't know until I test it but if anything you can always use a Simpson hybrid HANS which shouldn't be a problem..I think.
Old Oct 4, 2018 | 04:52 PM
  #33
WhiteBlack's Avatar
fun ones.
Nissan GTR doesn’t have harnesses, no Porsche runs spx and harnesses that I can think of. You can’t justify a **** setup because someone else does it too.
if you’re modding the car anyway just put a proper seat in?
Schroth ASMs are ok for occasional track use but if not setup correctly I’d rather be in a conventional 3point. When you install the cage you’ll see what I mean. They don’t work correctly in this car, the belts run over internal trim pieces, the only way to fix this is with an aftermarket seat.
Not or sure why anyone wants to half *** safety, like the old saying goes, buy a $10 helmet if you have a $10 head.
Old Oct 4, 2018 | 05:43 PM
  #34
MG1422's Avatar
GTR
I’m sorry I didn’t clarify. AFTERMARKET Nissan GT-R setups, AFTERMARKET corvette set ups, FACTORY Ferrari set ups. As for Porsche just because you have not seen it does not mean people don’t run them, check out GMG racing they use the SPX seat with a 4 point. So just to be clear all the above are s**t setups? Just checking.
I really dont don’t want to change the seat as of now and if I were to put a seat it wouldn’t be a pole position. I’m trying to make it the best I can for what I have in the USA.
A schroth 4 point will be a lot better to use on the USA seats vs a conventional 3 point on the track and they will be installed by a proper race shop, not myself.
I don’t think I’m half-assing with the setup I’m going for honestly but I did appreciate the helmet comment. I’m going to use that in the future.
Old Oct 4, 2018 | 08:46 PM
  #35
canucklehead's Avatar
Winnebago, Yugo
Man, what I would do alone with those brackets for 20 minutes(draft them actually)...
Old Oct 5, 2018 | 05:19 AM
  #36
WhiteBlack's Avatar
fun ones.
I see a huge amount of terrible aftermarket setups, I'd also say that probably 30% of harnesses I see at trackdays are not worn correctly (usually lap belt too high). As you say the pole position isn't a great seat for track use either, its part of the reason why I don't run harnesses on my GTR. I was actually going to replace them with something else but I'm now going to wait for the clubsport (and will mod that instead if I don't like the setup).
The shop that installs your harnesses will have the same issue as the factory cars, routing for the belts is not well thought out, the belt runs over the internal trim to reach your outside shoulder. In the event of an accident the trim will just crush and the belt will go slack. The only way to solve this is a seat with slots that sit higher than the standard options.
Mercedes refunded me the full cost of the track pack after I pointed out the errors in the setup.
Old May 22, 2019 | 05:15 PM
  #37
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
I have used OEM GTR roll cage coming up for sale.
Black in color if anyone still wants one.
Old May 22, 2019 | 05:24 PM
  #38
Winnebago, Yugo
Does it come with the brackets?
You want to ship to Canada?
Cheap?
I will take it.
Old Aug 12, 2021 | 11:45 PM
  #39
dbrad32's Avatar
amg gts
I will purchase if still available. I know this was posted a long time ago but
I will purchase if still available. I know this was posted a long time ago but thought I’d check.
