Let's Talk About Maintenance...
2. Pumping the oil out is an option for owners that have a Mityvac and prefer to avoid the huge mess caused by draining the oil tank. There is very little left after sucking it out and it won’t make a big mess. I have a Mityvac and I may use it next time to avoid the mess. For the last 20 years most of the MBs had the oil filter on top and the dipstick tube was positioned to direct the Mityvac tube at the lowest point in oil pan. It made oil change a breeze.
Like several other MB forums, owners share their own personal experiences, methods, shortcuts, repair procedures, maintenance, etc. There is no organization, business or other entity that reviews or approves the posts. So, no, Mercedes has no input here (wish they had in some cases), although there are MB service technicians that bring valuable info. I am sure that an administrator or moderator can point you to the disclaimers or fine print that can clarify this better.
1. Reaching it to temp while raised is not a problem. First take the car on a drive to reach temp. Then raise the car. If needed you can rev it on jack stands provided you do not put it in gear. Then shut off and drain. I have had no problem doing this and it is safe.
2. I have no mess when I drain the oil. I use a tall bucket and have short piece of PVC pipe that I fit around the oil drain hole. I then take the drain plug out and the pipe helps to nicely guide the oil into thre bucket. No mess.
I think oil change regularly (or more often than recommended) with proper oil by any method and you’ll be just fine. In my 30+ years of maintaining and frankly running the snot out of high perfomance cars I have never had an oil related issue. I always change frequently with synthetic oil and check levels regularly. My .02.
If anyone says running a car on a lift is safe, they should concede, that it’s less safe than running it while it’s on the ground.
You will keep your fingers and toes a lot longer, while wrenching, if you treat your work like it could bite you at any time, and take the least amount of risk, for the shortest possible periods of time.
Oil change and filter replacement, an in-cabin filter replacement, brake fluid change, fluid level check and correction, a multi-point inspection, wiper blade replacements and engine air filter replacement.
So by my calcs, yours is $900-$1000 ($150-$250 more) for the three without fluid level check and correction, a multi-point inspection, wiper blade replacements and engine air filter replacement. The OEM air filters and wipers are worth at least $100 without labor.
Code AF is below
Here are the service scopes for the C-Class W204 and therefore for all other cars (>2004).
- Service 1: Minor basic service (Service A)
- Service 2: Major basic service (Service B)
- Service 3: Engine oil + filter
- Service 4: Brake fluid
- Service 5: Combination filter
- Service 6: Dust filter (included in Service B)
- Service 7: Activated charcoal filter
- Service 8: Air filter
- Service 9: Tilting/Sliding roof
- Service 10: Panoramic sliding roof
- Service 11: fuel filter
- Service 12: spark plugs
- Service 13: coolant
- Service 14: main coolant circuit
- Service 15: trailer hitch
- Service 16: parking brake
- Service 17: emergency call system
- Service 18: brake algorithm
- Service 19: diesel particulate filter
- Service 20: automatic transmission oil and filter
https://www.jamescooke.me.uk/automot...orkshop-codes/
A – 505 – Service items 1, 3
A1 – D0D – Service items 1, 3, 4
A2
A3 – 550A – Service items 1, 3, 8, 11
A4 – D50J – Service items 1, 3, 8, 10, 11
A5
A6 – DD0S – Service items 1, 3, 4, 8, 10, 11
A7 – G50M – Service items 1, 3, 20
A8 – Q50V – Service items 1, 3, 10, 20
A9 – GD0V – Service items 1, 3, 4, 20
A0 – 850D – Service items 1, 3, 10
AC – QD051 – Service items 1, 3, 4, 10, 20
AF – KD001 – Service items 1, 3, 4, 8, 12, 20
AH – 801050E – Service items 1, 3, 13, 24
AG – VD0A1 – Service items 1, 3, 4, 8, 10, 11, 20
AK – 10D0E – Service items 1, 3, 13
AP – 15D0K
B – 606 – Service items 2, 3
B1 – E0E – Service items 2, 3, 4
B2 – 8E0N – Service items 2, 3, 4, 10
B3 – 560B – Service items 2, 3, 8, 11
B4 – B60H – Service items 2, 3, 8, 10, 11
B5 – 5E0K – Service items 2, 3, 4, 8, 11
B5 – 3E0H – Service items 2, 3, 4, 8, 12
B6 – DE0T – Service items 2, 3, 4, 8, 10, 11
B7 – G60N – Service items 2, 3, 20
B7 – GN061 – Service items 2, 3, 15, 20
B8 – Q60W – Service items 2, 3, 10, 20
B9 – GE0W – Service items 2, 3, 4, 20
B0 – 1607 – Service items 2, 3, 8
B0 – 960F – Service items, 2, 3, 8, 10 (on a GL63)
BD – M60T – Service items 2, 3, 8, 11, 20
BE – V6031 Service items 2, 3, 8, 10, 11, 20
BF
BK – 10E0F – Service items 2, 3, 4, 13
BS – 1Q60X – Service items 2, 3, 10, 13, 20
- Oil, Filter, drain plugs and gaskets - $110 (FCP Euro, lifetime)
- Cabin Filter $30 (FCP Euro lifetime)
- Brake bleeder tool and Castrol SRF - $220 (Amazon/FCP lifetime)
- Wiper blades - $40 Amazon
Material cost for second service a lot less as FCP has a lifetime replacement guarantee. - Yeah $1,000 seems excessive.
1. What is the best way to relieve fuel pressure in the absence of the MB tool? Is there another fitting that can work to relieve pressure at that port or will just cracking a line work?
2. Any tips on moving the breather lines to minimize damage?
Thanks!
Order no. P000 0055 13 Part no. 205 584 61 08 Edition B-2017
It includes Service A and B and Additional Maintenance work items 4 to 20. No items 1 to 3 listed. Items 21 to 25 do not apply.
Spark plug replacement is indicated at 90,000 kms (56,000 miles) or 6 years per Service 12
I extracted the pages relevant to the AMG GT and GT-S
