Ignition Coil failure
Old Nov 20, 2017 | 12:47 PM
06032's Avatar
2016 AMG GTS Edition 1, 2007 Alpina B7, 1987 560SL, 2011 E350 Wagon, Ural Patrol
2016 GTS. <3k miles. Fault codes P030022 and P030485 get launched. Problem identified as #3 Ignition Coil (177-906-95-00). Anyone else had this issue? What causes an ignition coil failure??
Old Nov 22, 2017 | 09:39 AM
06032's Avatar
Bump - anyone know why an ignition coil can fail? Dumb luck?
Old Nov 22, 2017 | 10:28 AM
ItalianJoe1's Avatar
2003 CL 600
Any electrical part can fail. There are updated coils for the 177/178 engines, there are multiple bulletins addressing misfires and ensuring that you have the newest coils. It should be fine after replacement, not a big deal.
The code you have is for Cyl #4 though, (p030485), if it was cyl #3 it would be P030385
Old Nov 22, 2017 | 11:33 AM
06032's Avatar
Thanks! Interesting. Report states that per Germany, they swapped them around to isolate the faulty unit. Fortunately it was repeatable. That one sporadic failure made a huge impact to driveability.
Old Nov 22, 2017 | 12:29 PM
cec69's Avatar
2016 GTS, 2017 S550 Cabriolet, 2015 911Turbo S 2016Q5, 2008 Z06
Vibration can cause coil failure but generally a coil fails over time trying to fire a fouled or bad, or excessive gap plug.
