I’m debating deleting my Secondary Cats...
Old Apr 25, 2019 | 07:21 PM
Orcbolg's Avatar
AMG
Originally Posted by Nwills
let me know if you get it done and we can meet up so I can hear your car!
I’m debating it as well and the place I called here in Oakville was very reasonably priced but they also told me that odds are I wouldn’t even be able to notice any difference at all!
Not sure what to make of it considering so many here have suggested it makes a considerable difference in sound?
This is still the best comparison I have found yet:
https://mbworld.org/forums/amg-gt/73...ml#post7705678
Old Apr 29, 2019 | 08:40 AM
MG1422's Avatar
GTR
I just cut the cats 2 days ago. Best $130 I've spent the car.
Old Dec 30, 2019 | 03:12 PM
fullvietfx's Avatar
AMG GTS
Best mod ever.
Old Dec 30, 2019 | 06:47 PM
AMG 17GT's Avatar
R Nine T
The Particulate filter will be next delete on new cars.
Old May 15, 2020 | 02:25 PM
GTSEdition1's Avatar
Corvette Z06
For those who got the resonators deleted. Did you get a TIG or MIG welded? Any preference of one over the other?
Thanks in advance!!
Old May 15, 2020 | 02:27 PM
MG1422's Avatar
GTR
Thanks in advance!!
pretty sure the shop I did it at was TIG welded
Old May 15, 2020 | 02:55 PM
  #32
Corvette Z06
Thanks MG. I am debating how much of a difference it makes. The guy who is willing to do TIG in my area is asking for $500, whereas, the regular job (MIG) I have heard can be done for $200-250
Old May 15, 2020 | 04:18 PM
  #33
t3flondon's Avatar
2003 CL55 AMG 2019 C300 Coupe 2017 AMG GTS 2020 A 220
Dude, no! Way to high for either, $200 max for MIG, mine was done for $150 here in LA, My other car was done TIG for $300ish, Honestly either way will not make much of a difference in my opinion. (note: my girl thinks I am wrong all the time)
Old May 18, 2020 | 02:44 PM
  #34
jvojvo's Avatar
amg gt
I thought I was pretty clear on this until I read a couple of the replies. exactly where are the secondaries? back by rear axle or further forward? is the "panel" easy for them to remove and will they know where cats are to remove proper panel??? thx!
Old May 18, 2020 | 02:54 PM
  #35
t3flondon's Avatar
They are located just under the engine where the pipes come down.
Old May 18, 2020 | 03:58 PM
  #36
jvojvo's Avatar
amg gt
thx so much, perfect pix!!! there is a panel covering that area?? just a few screws to remove?? and cut, weld, and done??
Old May 18, 2020 | 04:07 PM
  #37
MG1422's Avatar
GTR
That is correct!
Old May 18, 2020 | 04:33 PM
  #38
jvojvo's Avatar
amg gt
sounds very doable!! with good results!
Old May 18, 2020 | 04:37 PM
  #39
t3flondon's Avatar
And the cheapest mod at less than $200 bucks you can do besides window tint and fuzzy dice.
Old May 21, 2020 | 11:59 AM
  #40
tblountman's Avatar
GTC Roadster
Just one quick question before I get this done.... anyone have any drone issues at all?
Old May 21, 2020 | 12:38 PM
  #41
MG1422's Avatar
GTR
none!
Old May 21, 2020 | 08:53 PM
  #42
t3flondon's Avatar
Nope, the only sound other than the V8 is me making engine sounds as I smile and rip up the street.
Old May 22, 2020 | 04:37 PM
  #43
oyalomar's Avatar
AMG GTS
Guys I've heard that deleting secondary deletes may lead to some air sound which makes it worse a bit.
I've also heard a video in another thread and the sound wasn't clear.
Is there any better quality video can be shared by anyone who deleted the secondary cats?
Old May 22, 2020 | 04:48 PM
  #44
t3flondon's Avatar
Here ya go, excuse the dirty car, it had just rained, also did it from inside to outside car, that's where you sit to hear it most of the time. In Sport+ mode.
Old May 22, 2020 | 04:50 PM
  #45
oyalomar's Avatar
AMG GTS
In which mode is this video?
Old May 22, 2020 | 05:15 PM
  #46
t3flondon's Avatar
Sport+
Old May 22, 2020 | 05:19 PM
  #47
oyalomar's Avatar
AMG GTS
Great Video!
Thank you for your quick response
Old May 27, 2020 | 01:08 PM
  #48
tblountman's Avatar
GTC Roadster
2 quick questions... my fab guy is a perfectionist and wants to know what type of stainless it is... and also needs to know the pipe diameter... thanks for the help... he also suggested putting an x pipe in but I don't think i want to do that.
Old May 27, 2020 | 01:55 PM
  #49
t3flondon's Avatar
Someone chime in if I am wrong, there is nothing wrong with being a perfectionist, in my opinion, and I have owned and modified a lot of high end vehicles over the last 35+ years, that mod no matter what you use, pipe, material etc, is not going to make much difference in performance or sound, upgrading down pipes, exhaust system will, but not just the pipe used for removing secondary cats, just make sure that the weld is good but sounds like he is a perfectionist. lastly there is a debate on if the pipe should go over or inside the removed cat ends, and X pipe is another debate that can go on as well.
Old May 27, 2020 | 07:32 PM
  #50
UCIMBZ's Avatar
E55, 380SL, GLA 250 Sport, AMG GTS
X-Pipe only works if you have two parallel pipes running side by side so where you remove the resonator (cat) you make the pipes to cross over so it creates some kinda back pressure so not to lose power. In the case of the GT you have two single pipes running on either side of the car so an x-pipe can not be applied.
