Replace front bumper trim
Old Mar 28, 2019 | 12:35 AM
nolaGTS's Avatar
2016 AMG GTS Coupe
I'm not sure the exact term for this piece, but it's the rubber or plastic trim at the bottom of the front grill. It essentially protects the front bumper from scraping when leaving a steep driveway or something. Anyway, mine has come off in the center and is sagging some. the pins that hold it in aren't just screws, but something I'm afraid to remove. Has anyone had experience replacing this piece or simply reattaching it? I'm sure this question has been posted before but I'm not sure how to phrase it to effectively search the forum.
Old Mar 28, 2019 | 09:29 AM
Alexfor8's Avatar
Top Answer: 1
2016 AMG GT-S | 2016 Ferrari F12
Those are rivets. I just ripped mine off and threw it away.
Old Mar 28, 2019 | 08:02 PM
BucsFan's Avatar
'18 AMG GTC, '96 BMW 318i, '25 Ram RHO
Mine ripped in half when I pulled my hose under the nose of my car. It's seems like an afterthought. Certainly not engineered like the rest of the car. It can't be helping the aero. I agree with Alexfor8. Pull it and toss it.
Old Mar 29, 2019 | 12:37 AM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
You guys referring to the rubber piece way underneath to prevent scratching the bumper?
Old Mar 29, 2019 | 01:47 AM
nolaGTS's Avatar
2016 AMG GTS Coupe
Yes sir. I have a friend who also had a GT S and he had the same problem. He did what the fellas above recommend and simply took it off. Scrapes are damn near inevitable no matter how careful, which is why mine is sagging now in the first place. So I think this could be a good thing to have. What's your take on it?
Old Mar 29, 2019 | 01:53 AM
ZephyrAMG's Avatar
Personally I think any kind of buffer between the ground and your expensive bumper is good. I have had that rubber piece save me a couple times from scratching a brand new bumper . There is a member on this formum who is fabricating and selling a really tough and good skid plate which I am looking into . This car sits rather low and it would be a shame to just scrape up the front artwork on the car. However if it’s just a limp sagging piece of rubber I guess it doesn’t make any sense to try to salvage it ...
Old Mar 29, 2019 | 08:19 AM
dlefty's Avatar
/////PRO
Those are rivets, they must be drilled out, and replaced by installing new ones with the rivet install tool.
Old Mar 31, 2019 | 07:33 PM
Katie22's Avatar
18 AMG GTC and 22 F150 Limited. Past owner 16 Maybach, 17 Brabus Smartcar, 06 Ford E150, and 22 G70
I had my piece come loose. What I did was buy stainless steel screws and loosen the entire panel that holds the loose piece so I could get to the inside. I cut the rivets out and reinstalled the piece with the stainless steel bolts with stainless nylock nuts.... all is good for many miles.
The reason I did not use rivets again was because the heads on the rivets were not very wide and this was what allowed the piece to come loose in the first place. With the stainless steel bolts I was able to use a washer to make sure piece would never pop off again.
Old Apr 1, 2019 | 01:31 AM
invictusmaneo's Avatar
Lifted G500, GT-S, track Cooper S
Do you have more info or a link on the scrape guards? I've been looking into options.
Old Apr 1, 2019 | 06:59 AM
matteRAT's Avatar
2024 AMG G63, AMG GTC Edition 50 Coupe
The forum member that fabricates the scrape guard is SDAutoSalon.
Old Apr 1, 2019 | 04:19 PM
ZephyrAMG's Avatar
Yes its SDAutoSalon. Matte is right. He is fabricating a thick polyacrylic bumper scrape guard. I think it was originally a design pulled from corvettes. Maybe they can mention something more about it and/or create a group buy. Maybe some pics too...I am very interested.
Old Apr 1, 2019 | 04:45 PM
I reached out to them to see their response. The original post was for a GTC, so I would be interested to see compatibility/options on GTS as well
Old Apr 1, 2019 | 05:13 PM
Orcbolg's Avatar
AMG
When I talked with him about it, he said that there would not be any fitment issues with the GTS.
Old Apr 1, 2019 | 08:34 PM
California John's Avatar
2022 AMG SL63
You can tell the racer in Katie. Stainless nylock nuts. What we used to use.
Old Apr 2, 2019 | 07:16 AM
Katie22's Avatar
Ha Ha
