Lowering Springs Labor Hours
How many hours should I expect a quote for an install on a set of H&R springs for my '16 GTS? Anything special to look out for on the install so there are no surprises to me and to the installer?
Thanks in advance.
Thanks in advance.
No surprises, but have 2 packs of alignment shims ordered and in your hands prior to install so you can throw it right on the rack after and properly align, WILL be needed with those springs.
Super Moderator
Received 3,303 Likes
I'm assuming labor would be the same with the KW HAS?
Super Moderator
I already have the springs... I know the KW option is better but I wasn't sure I'd keep the car since a GT R has caught my eye... And if I remain in love with my GT S (more and more likely with each passing day), then I'd look into just getting a proper set of coilovers down the road.
This would be the first GTS... But they do work on a lot of Porsche racecars and streetcars. Not sure how much different the GTS is.
Super Moderator
Given that they have to disassemble the interior panels, etc. for the rears, it’ll be nice not for them learn on your car and then bill you for it...
thebishman (06-13-2019)
$60.00 -
At first read I thought that was a mis-print -
You want an alignment where they use weights
in the drivers area
that correspond to your weight -
Thank-You
D.B.
$60.00 -
in the drivers area
Thank-You
D.B.
‘24 BMW iX M60
My independent shop that does the non-warranty work on my GT R has set aside 1/2 of a day minimum to re-align the car with the two packs of shims I purchased for them to get a more aggressive alignment. A quote of $60 means that your ‘shop’ has no idea what they are talking about re: suspension work on the GTS. Look elsewhere.
Bish
Bish
So it seems 5-6 hrs is the standard for the coupe. However I was told by one installer that the roadster (which I have) is much more difficult to do. Entails almost removing the soft top. Closer to 15 hours! Is this accurate???
2020 McLaren 720s Spider
I had a roaster GTC - take it somewhere else - its marginally more difficult but 1000% not a chance that its double. If they were to change you an extra hour that would cover the added time in the cramped space to get it done.
