Anything I should know. New Battery install. GTS
Old Dec 2, 2019 | 08:16 AM
john5's Avatar
AMG GT S
Hello,
The car is completely dead, no power no dash lights nothing. Advanced Auto has a replacement battery for $220 I’ll pick up today. Just wondering if there is any procedure or system I should follow dropping the new one in. And also, is there an auxiliary/consumer battery on this car that may need replacing? 2016 Amg Gts
Thanks,
Old Dec 2, 2019 | 08:20 AM
paizesb's Avatar
2016 AMG GT-S
Hi John5
I just replaced my battery under warranty for a GTS
The battery on a GTS is a lithium ion battery so its quite expensive was around $1700
make sure its correct @ $220 not sure it is correct battery
Old Dec 2, 2019 | 12:22 PM
john5's Avatar
AMG GT S
Hello, Thanks for reply.
I understand I am sacrificing li-ion battery weight lbs for my wallets sake but I was just looking for anything else I need to look for after first fire. I’ve read some things about having to reset computer/system or something of that nature. Anyone else has had to disconnect and reconnect battery with any issues?
Thanks,
Old Dec 2, 2019 | 12:44 PM
thebishman's Avatar
‘24 BMW iX M60
John,
Have you attempted to charge the battery back to health with a specific Li+ ion battery charger?
Bish
Old Dec 2, 2019 | 12:47 PM
hyperion667's Avatar
2012 CLS63
Originally Posted by paizesb
Hi John5
Old Dec 2, 2019 | 01:16 PM
john5's Avatar
AMG GT S
Bish,
Thanks for the recommend. I currently do not own a Li- charger and since the battery has been fully depleted, I’m figuring it’s rendered useless. Or there’s a fail safe level. I’ll have more reading to do on that one. I have seen the Ctek Li- chargers on-line for about $100.
Old Dec 2, 2019 | 07:13 PM
BucsFan's Avatar
'18 AMG GTC, '96 BMW 318i, '25 Ram RHO
I stupidly discharged my battery after owning the car for only about a month. MB auto club sent a tech to jump it. It started fine and I went on a long drive to charge the battery. It's been fine for the last 18 months.
Old Dec 2, 2019 | 08:26 PM
descartesfool's Avatar
AMG GT-S, AMG C43, Ferrari Roma, Maserati MC20, Genesis GV70 Electrified
Why not just jump start the car and run it for an hour or more and see if the battery gets at least partially re-charged. If it does, you can just drive it and recharge the battery. Jump starting procedure is in the owner's manual on page 218. You can just connect a second regular battery to the jump start terminals and go for it. My GT-S came with a Li-ion battery charger which I connect to the lighter socket in the trunk over the winter months.
Old Dec 3, 2019 | 06:57 AM
john5's Avatar
AMG GT S
Hey guys Thanks for the reply's.
I ended up at Costco, they just started carrying a nice AGM battery. And Costco, their policy bring it back anytime if you have a problem 3,5,10 years doesn’t matter. Threw it in car fired right up but now have check engine light and malfunction light on in center cluster. I’ll have to see what those are all about.
Old Dec 3, 2019 | 01:14 PM
tony cls63's Avatar
2009 Dodge Viper 2019 GTR 2017 S63 coupe 2014 Rubicon X 2014 GL63
I think you’re charging system is specific lithium ion battery
Old Jan 27, 2020 | 11:54 PM
jnash's Avatar
2017 S63
MB lithium Batteries are smart and need to be coded when replaced. You can’t just swap in a new one.
the car circuit protects this type of battery when it’s voltage goes belies about 11.5 volts and will shut off the car and make you think the battery is dead. Jump the car and let it idle for 10 minutes.
since you changed to a new battery and now have a check engine light, if you still have your MB OEM try reinstalling it and using the above procedure. You mind find there is nothing wrong with it once it’s instructed by the car to wake back up.
Old Feb 12, 2023 | 07:16 PM
mercedesflorida's Avatar
1-GTS AMG 2016 and 2- AMG S633
mercedes fllorida
does anyone know if there is any aftermarket lithum batteries for a GTS MG 2016 ??
apparently there is a back log order to obtain an orinal opne from the dealear , I have been wating for 10 weeks and still no ETA
MG
Old Jul 17, 2023 | 03:39 AM
2016AMG-GTS84's Avatar
2016 AMG GTS
MG
im having the same issues. Just ordered a 60Ah antigravity battery to replace the OEM one. Will let you guys know how it goes.
Old Jul 25, 2023 | 12:32 AM
2016 AMG GTS
happy to report back that I just changed out the OEM battery with the antigravity 60Ah lithium battery. Car started right up and went for a nice drive with no problem.
The bolt holding down the battery is a bit tricky to get to, but with a wrench socket extender makes it pretty easy.
hope this helps for anyone with same issues.
Old Jul 26, 2023 | 07:38 AM
matteRAT's Avatar
2024 AMG G63, AMG GTC Edition 50 Coupe
Would you please share with everyone the exact brand, type, and model number battery you used. Also did you have to get anything recoded in your car by Mercedes tech or were you able to just do the swap on your own? We all thank you for your help!
Old Aug 27, 2023 | 02:54 PM
AnoMG's Avatar
AMG GTS
Which battery is really dead?
Hello all,
Driving the AMG GTS and the car sputtered then cut off power steering, automatically went into neutral, and showed a million faults on the dash. I turned the car off and sat the there, turned it back on, everything was fine then it all happened again. Mercedes dealership says the starter battery ($2,400) is dead, but the car starts over and over no problem. They say the battery is on back order with no ETA on when it will be in. I’m assuming it’s the other battery ($700) that’s supposed to run everything else but they say it’s not. Anyone familiar with this scenario and know of a place where I can get another Li Ion battery of they are right?
Old Aug 27, 2023 | 03:21 PM
2016 AMG GTS
sorry for taking so long to reply. I’ve been on a few trips and totally forgot about this thread.
see the link below.
the 60Ah one works just fine and has enough power to start the car. I just left the extra connector off no issues or fault codes. Probably put 200 miles on the car since the battery change
https://antigravitybatteries.com/pro...tive/ag-h6-rs/
Old Aug 27, 2023 | 08:05 PM
MalibuScott's Avatar
2025 Lucid Air Grand Touring, 2022 F-150, 1926 Rolls-Royce SSG roadster
Originally Posted by AnoMG
Hello all,
What state are you in? If California you can threaten a Lemon law recall if the car is not repaired in 30 days. And that would include a new battery if the car is still under warranty.
Old Aug 28, 2023 | 10:23 AM
AnoMG's Avatar
AMG GTS
I live in AZ. Had the car almost 2 years and it’s a 2016 so doubtful I can use that route. Great piece of advice though!
Old Aug 29, 2023 | 12:16 PM
BBS63's Avatar
Schwinn
Hello all,
I could be wrong but I am almost certain that our cars have only one battery and not two like some other models where they have the Tonka truck little battery hidden in the car.
As far as getting one from somewhere else that a dealer for replacement, Advance Auto Parts sells AGM batteries that should work. But you will probably need to reprogram the car to the new battery, I can swear someone posted about this where he took his car to a auto parts store installed the battery and they were able to code it right there.
Its worth a shot, beats not being able to use the car because Benz is out on a trip blowing bubbles in the park and wondering why the bubbles are popping.
Old Aug 29, 2023 | 12:23 PM
jm246's Avatar
2015 GLA45 AMG, 2017 AMG GT S
Thanks for sharing the update on the Antigravity battery @2016AMG-GTS84 - great know its pretty much a plug and play!
I've had an AGM battery in my 2017 GT-S for just over a year, but the car was throwing error codes which lead to the annoying error message attached below.
I worked with @BenzNinja to code out the car looking for the OEM Lithium-ion battery and after many long and spirited drives I can also vouch for that also being a viable option!
Now that I know the Antigravity works, I'll consider that as a "nice-to-have" upgrade for the future 😏
Error message due to the car looking for the OEM Lithium-ion battery
Old Aug 29, 2023 | 12:24 PM
jm246's Avatar
Can also confirm that there is only one battery - the starter battery in the engine bay - at least with the 2017 GT-S 👍
Old Aug 29, 2023 | 03:07 PM
AnoMG's Avatar
AMG GTS
Good to know, looking to go see if I can find a comparable one elsewhere. Thanks!
Old Aug 29, 2023 | 04:23 PM
BenzNinja's Avatar
Former Vendor
Thank you!
Old Aug 29, 2023 | 08:50 PM
2016 AMG GTS
there is another small AGM auxiliary battery in the trunk, not important for any major operations though.
