Error after installing Eurocharged Stage 2 tune
Old Jan 4, 2020 | 05:16 PM
1968mustang's Avatar
2018 C43, 2016 GTS
Hi all - Hoping this forum can help. I have a '16 GTS and purchased the Stage 2 tune from Eurorcharged. After getting the tune file uploaded to the tuner today, I proceeded to upload it to the car. Everything went fine except now I get an "SOS - Service Not Activated" error on the instrument cluster display. After a bit of googling, this appears to be something related to mbrace, but I can't find a remedy and Eurocharged is closed until Monday. Anyone know what the issue is and how to fix it?
Old Jan 4, 2020 | 06:57 PM
502Bill's Avatar
AMG GTS
You can ID the error code with a scan tool to be certain, but more than likely its an error in the tune. I had a similar experience due to running with no cats. They fixed to issue quickly and I haven’t had another problem since.
They will ask you to pull the stage 2 tune off the car and send it back to Eurocharged. They will take a look and make adjustments.
You can get ahead of the game and pull the tune off, upload the stock tune then email the stage 2 back to Eurocharged now. They should get back to you within 24hrs Starting Monday.
Old Jan 4, 2020 | 09:08 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
didnt use a charger when applying the tune
disconnect your battery for 20 mins and reconnect
Old Jan 5, 2020 | 09:03 AM
2018 C43, 2016 GTS
Sent you a PM.
Old Jun 12, 2020 | 07:45 PM
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
Call HQ’s here in Houston. Talk to the owner.
Old Jun 13, 2020 | 01:40 PM
SLOWCAR930's Avatar
13 997 turbo s,07 G55,58 apache
your lucky at least you EC tune started after you got it done. They suck
Old Jun 13, 2020 | 02:20 PM
///Bruce's Avatar
If you think it’s bad on the W205, check out some issues they’ve been having with the W204’s.
Old Jun 13, 2020 | 02:33 PM
SLOWCAR930's Avatar
its just not right $1000 is a lot to loose live and learn i guess. Who would take a mclaren there end up with a 86 lebaron software in your car Ha ha
Old Jun 13, 2020 | 06:01 PM
Orcbolg's Avatar
AMG
I have no idea what you're even talking about in this thread.
Old Jun 15, 2020 | 09:31 AM
SLOWCAR930's Avatar
1968 mustang said he has issues after tune. I replied at least his started. Because after my ecu tcu EC tunes my G wont start. In 4 years when i post something again i will try and be more clear. Sorry about that.
