Can I go 325/25/20 in the rear??? Would you?
Old May 16, 2020 | 08:38 PM
BucsFan's Avatar
'18 AMG GTC, '96 BMW 318i, '25 Ram RHO
I am concerned that the 275s are too wide for the 9" width fronts. Will you track this? If so, I would love to know how it goes.
Old May 16, 2020 | 09:36 PM
Hetzle's Avatar
2016 AMG GT-S
Originally Posted by x96535
That’s exactly what I have, and I’m surprised to say they actually hook very well.
That's what I'm aiming for - awesome!
Old May 17, 2020 | 08:48 AM
Rock's Avatar
Administrator
Drives Slowly
I won't be tracking the car but the PS4S 275/35/19 should fit the stock wheel without an issue.....hopefully. My car has the stock suspension and I have no plans to install KW HAS or lowering springs.
Old May 17, 2020 | 09:06 AM
Orcbolg's Avatar
AMG
They do, I have had them on in that size for nearly a year now.
Old May 21, 2020 | 11:30 AM
Hetzle's Avatar
2016 AMG GT-S
Turns out my wheel manufacturer did not make my front wheels to spec and are having to remake them. They've made wheels for a handful of these cars and are unsure of what went wrong. So, for now I am running a lopsided car with stock wheels/tires up front and 325/25/21 in the rear and Renntech coils. Here are my first impressions:
  • I love the ride! It is way more supple than the KW sleeve kit that was apparently on the car (had no idea when I bought it). Comfort feels pretty darn comfortable now, and Sport+ feels like Comfort did on the KW's.
  • Suspension in Comfort mode: I experience rubbing over larger bumps. There is a particularly horrendous road outside my tech's shop and I experienced a bone-shaking "THUD" over a couple major deformities. This honestly scared me a bit and I wondered if I had ruined the car with my choice of tire/suspension. Driving 45 miles of freeway back to San Francisco, I experienced 2 instances of rubbing - one over a dip while cornering at 7/10 into an off/onramp, and one other over a very large dip. Medium size dips seem fine, cornering on well paved roads doesn't seem to cause rubbing.
  • Suspension in Sport+: there seems to be less chance of rubbing, but I tested over some metal plates in a construction area in SF and still experienced light rubbing in the rear
Here are some pics of how she sits today. I know the springs will settle in a bit, causing the car to get even lower.
Does it have to do with the fact that there are 19's up front and 21's in the rear? Suspension too soft? Too low? Tires too wide? Can we roll the fenders? My mind is racing trying to figure out a way to make this work...
I think I will have it raised a bit and would love to hear if anyone has advice on how to reduce rubbing other than reducing tire size (that will be my last resort, after I finish these tires).
Can I go 325/25/20 in the rear??? Would you?-qecjkw5.jpg
Can I go 325/25/20 in the rear??? Would you?-z4rpuet.jpg
Old May 21, 2020 | 11:48 AM
x96535's Avatar
2016 AMG GTS
I’m a little surprised you’re rubbing with that much gap. I’m guessing your spring rate has to be a lot less than the H&R’s that I’m running. There is an option to help raise it, though I’m sure some on here will scoff at it.
This product is used by virtually every sprint cup car to adjust the spring rate between tracks. If a racecar can use it, then I see no problem running it on my daily that gets some occasional high speed cornering.
Here is the product: http://www.longacreracing.com/produc...-Spring-Rubber
Here is the YouTube video walking through the install:
Here is a pic from mounting on my car yesterday:
I, too, was getting some rubbing over some medium to heavy bumps with my new wheel/tire setup and lowered on H&R. Now I really, really have to try to get it to rub over large bumps, dips at high speeds.
I was actually less worried about the rubbing before but more concerned that the H&R springs on both my factory and aftermarket wheels have the rear sitting about 5/8” lower than the front. I called H&R, and after looking at pics, they said this was normal. I think that’s ridiculous. Using the orange insert, it raised my rear about 3/8”. I’d consider using the red insert in the future to bring it perfectly level with the front.
Hope this helps. Worst case you’re out about $100, and you don’t like it. Best case, it’s a simple fix for $100.
Old May 21, 2020 | 12:03 PM
  #32
Hetzle's Avatar
2016 AMG GT-S
https://youtu.be/4UsGilmmhfI
[REMOVED TO SAVE SPACE]
I was actually less worried about the rubbing before but more concerned that the H&R springs on both my factory and aftermarket wheels have the rear sitting about 5/8” lower than the rear. I called H&R, and after looking at pics, they said this was normal. I think that’s ridiculous. Using the orange insert, it raised my rear about 3/8”. I’d consider using the red insert in the future to bring it perfectly level with the front.
Wow, this looks like it might be what I need! Thank you. Couple questions: Did you put it on only the rears? Also I think the quoted area I bolded was a typo, was the front or rear lower?
Also yeah I am very surprised about the rubbing given the gap too.
Old May 21, 2020 | 12:06 PM
  #33
x96535's Avatar
2016 AMG GTS
Wow, this looks like it might be what I need! Thank you. Couple questions: Did you put it on only the rears? Also I think the quoted are I bolded was a typo, was the front or rear lower?
Yeah, that was a typo. The natural stance for the H&R is to have the rear about 5/8” lower (per wheel gap - not fender to ground) than the front. I only did this on the rears. No rubbing on the fronts from what I can tell.
Old May 21, 2020 | 12:08 PM
  #34
Hetzle's Avatar
2016 AMG GT-S
Gotcha, thanks a bunch! I think I'll order the red ones after the suspension settles in more.
Old May 21, 2020 | 12:15 PM
  #35
AMG 17GT's Avatar
R Nine T
On the large dips are springs bottoming? I would simply crank up 1/4- 1/3 inch all around. If I can ever get my car back into the shop I’m cranking it up a little less than a half an inch as the bottom of my car is scraping on severe angles as a result of RTECH springs settling.
if you keep getting the severe rub that you indicated, I would change tires out as it’s just not worth the chance you’ll damage the car.
Old May 21, 2020 | 12:48 PM
  #36
x96535's Avatar
2016 AMG GTS
Let me know if the red ends up making you sit too high. We could do a swap.
Old May 21, 2020 | 12:56 PM
  #37
AMG 17GT's Avatar
R Nine T
not sure why he would need these as his springs are adjustable.
Old May 21, 2020 | 01:03 PM
  #38
Hetzle's Avatar
2016 AMG GT-S
My understanding is it adjusts the spring rate- the reds would make it harder to compress, thus reducing the rub in exchange for a proportional stiffening of the suspension.
Old May 21, 2020 | 01:04 PM
  #39
Hetzle's Avatar
2016 AMG GT-S
The website says they all are 3/4" in height, but differ in terms of stiffness
Old May 21, 2020 | 02:57 PM
  #40
AMG 17GT's Avatar
R Nine T
I see.
Old May 21, 2020 | 06:39 PM
  #41
x96535's Avatar
2016 AMG GTS
Right, but I'm guessing that's 3/4" in height uncompressed. I'd assume a stiffer material would compress less, therefore making the lift greater. I'll also try moving the orange ones to a different location within the spring - somewhere that the spring gap is normally less, to see if that helps raise it some more.
Old May 21, 2020 | 11:53 PM
  #42
Hetzle's Avatar
2016 AMG GT-S
Ohhh hadn't thought of that. Makes sense!
Well the rear has settled in a bit more and is definitely still rubbing on medium sized bumps in Comfort - I'm pulling the trigger on those inserts.
Can I go 325/25/20 in the rear??? Would you?-6frxifd.jpg
Old May 22, 2020 | 12:03 AM
  #43
Hetzle's Avatar
2016 AMG GT-S
Sorry missed this earlier - the springs did bottom out on large road deformities. I'm talking like nearly a foot's worth of bump. Outside of that environment I just felt rubbing, no bone shaking thuds.
On the plus side, the traction is amazing! I dead hook in 1st and 2nd for the first time ever and it feels THRILLING.
Old May 22, 2020 | 12:15 AM
  #44
x96535's Avatar
2016 AMG GTS
Forgot to mention, your car is killer! Can’t wait to see it with the full wheel setup. I watched a blue GTS with carbon ceramics sit on a dealer lot for about a month at a fantastic price before I was ready to move on it. Then it disappeared about two weeks before I was ready. Very jealous!
Old May 22, 2020 | 01:52 PM
  #45
Hetzle's Avatar
2016 AMG GT-S
Thanks, I can't wait either haha. Your car looks amazing too, I definitely want to follow your lead on vinyl over the orange reflectors.
Old May 28, 2020 | 07:20 PM
  #46
Hetzle's Avatar
2016 AMG GT-S
Front wheels are shipping out today, and I heard from Renntech that they ran this size tire on their drag car and that the car needs to be raised a bit.
Old Sep 9, 2022 | 02:48 PM
  #47
Bilbo7's Avatar
2015 SL63 AMG (R231)
Sorry I posted on the wrong thread
Old Jan 8, 2025 | 11:24 PM
  #48
coconutpropane's Avatar
I went from 305/30/20s to 335/30/20s PSS on my GTC. They look awesome, especially since the 12" rims were under-tired with the 305s. They definitely reduce oversteer, especially if I am a little quick on the throttle out of a turn on track. I will switch to PS4S 325/30/20 when these are done.
I’m considering this upgrade now for my GTC with stock wheels. Did you need spacers at all for the 335/30/20s? I want them to be flush with the fenders. Also, what are you running in the front?
Old Jan 9, 2025 | 04:11 PM
  #49
G. P's Avatar
2020 AMG GTC
The 335/30/20 tires fit perfectly on the OEM rear 12" rims with no need for spacers. If you prefer a slightly more aggressive look, you could likely add a 5mm spacer to make them stick out a bit more. Check out the photo of the 335/30/20 tires mounted on the OEM rims without spacers. For the front, you'll need to size up to 275/35/19. I had no issues or rubbing with this setup. (I haven’t tried 285s on the front, so I can’t confirm fitment for that size.)
Old Jan 11, 2025 | 04:45 AM
  #50
untamedd's Avatar
2019 AMG GT R
I would prob want to swap out the pilot sport cups too.
would anyone know whats the max width tyre a gtr can take in the front/back on oem rims without any rubbing? Thanks
