OEM GTC Coupe Rear Wing - Anyone interested?
Old Sep 4, 2020 | 09:53 AM
William23's Avatar
C450 AMG
hey guys, just put the OEM rear wing on my black 19 GTC coupe and think I wanna go for a more aggressive look with the GTR rear wing instead. Anyone interested in buying the one I just had installed? Thinking $2500 shipped in the US if interested.
Old Sep 30, 2020 | 05:47 PM
Jack Huang's Avatar
GTC
hi how do you shut down the auto spoil after 120km/h
Old Sep 30, 2020 | 06:23 PM
William23's Avatar
C450 AMG
There is a rear spoiler delete. Its plug and play and uses MB connections to ensure it doesn't throw a code. Works great! Comes with the wing im selling
Old Oct 4, 2020 | 04:09 PM
Saudio's Avatar
AMG GT C
OEM? Mercedes makes a rear wing for a GTC? I googled and couldn't find one.
Old Oct 4, 2020 | 04:47 PM
William23's Avatar
C450 AMG
Its the OEM wing for the GTS. I put it on my GT C Coupe.
Old Oct 4, 2020 | 05:16 PM
Saudio's Avatar
AMG GT C
Ah! How did you fasten it on? Is it reversible to stock without replacing the factory wing that came with the car?
Is it functional aerodynamically?
Thanks!
Old Oct 4, 2020 | 05:47 PM
William23's Avatar
C450 AMG
Thanks!
Its put on the GTS so its certainly aerodynamic in nature but I wouldn't say its wildly functional like the GTR Pro style wing. If you have a GTC you just need the bypass for the electronic wing which is plug and play. Super easy. Otherwise it just bolts on.
Old Oct 4, 2020 | 05:51 PM
Saudio's Avatar
AMG GT C
Thanks!
What does it bolt on to? Since it is for a different model, do you have do drill holes?
Old Oct 4, 2020 | 05:54 PM
William23's Avatar
C450 AMG
Thanks!
the base of the wing matches up to the base on the electronic wing. All the pieces inside are mostly pre drilled. You may have to drill one or two out but the piece and placing are already marked as they use the same base plates inside. Very easy.
Old Oct 4, 2020 | 06:13 PM
Saudio's Avatar
AMG GT C
Please forgive me for so many questions, but can you tell me if you have to drill any holes which would be visible if you removed the wing and went back to stock? Would I have to make any repairs after removing the wing?
Old Oct 4, 2020 | 06:45 PM
William23's Avatar
C450 AMG
no worries. No, to put it back to stock you just unplug the wing disable and insert the old base plate. You're not modifying it in any other way from stock other than possibly drilling out some pre marked holes from the base plate.
Old Oct 4, 2020 | 09:41 PM
Saudio's Avatar
AMG GT C
Thank you. I have not yet even collected my car but I like the look of the wing and I may consider it after I see the lines of the car in real life.
Old Nov 28, 2021 | 10:46 AM
AndrewFerg's Avatar
AMG GT C Edition 50
Update?
Did you keep this wing or do the swap? I'm thinking of adding the GTS OEM to my GTC. But mine is matte.
