2020 AMG GT R Pro
Like others said, the oil level sensor is extremely sensitive in these cars, sometimes that warning message come up after I tracked the car for a day, you'd think there should be oil burnt instead of excessive..
I just ignore it, the dry sump system has a lot of tolerance, and I usually just measure when oil is warm (200F+), and use the stick to determine.
This engine does need 7L or 7.4QTS. If you know you're only 5.1 you want to correct the oil level; however, 5.1QTS would definitely set a warning message.
The way the oil is changed in this platform is critical to follow the procedure. You were at an MB dealer and I guess we should assume they know the procedure. If they did not follow it, likely it will result in an overfill which you first reported. Here is the process. It includes some upfront steps and a timing step. I suspect the 3min part was exceeded.
If these steps are not followed, especially the 100*C engine oil temp, 30 sec or more idling in neutral, and the 3 min drain time, then likely as much as a quart of oil stays trapped in the cooler and lines behind a thermostat that closes. Maybe the MB dealer didn't follow these steps.
On checking the oil level with the stick, it too has a critical time window in which you have to check the level properly. For similar reasons as the drain process, the oil level can change in the tank giving an incorrect reading if you wait too long, and if the oil temp isn't up to op temps and idling for 30 sec in neutral in mode C.
Suggest you consider following the steps right above and get an accurate reading on the dipstick, then correct the level.
So, if they don't get the oil temp up, the tstat to the oil cooler will not open. If they bring it in cold and just dump the oil (Pretty darned sure this is it), there easily will be a QT of oil left in the cooler and lines. Then when they add 7.4 QTS on the fill.....car now probably has 8 1/2 QTS of oil in it.
OR,
They're smart and only put 6 qts of oil on the refill which would be an 81% oil change. Some old oil and some new oil....
CUSTOMER STATES THAT THERE IS A MESSAGE ON THE DASHBOARD "HIGH
OIL LEVEL" PLEASE CHECK AND ADVISE.
184110 W67 REPLACE SENSOR FOR N/Cp
OIL LEVEL INDICATOR
Tech(s): 5346
091-905-71-01 1 FILL LEVEL SENSOR N/C
001-997-72-41 1 SEAL RING N/C
000-989-79-02-19-BIFU 6 229.5 5W-40 N/C
Pts: 0.00 Lbr: 0.00 Other: 0.00 Total Line A: 0.00
Story: 6888 HIGH OIL LEVEL ON IN DASH W- CONFIRMED HIGH OIL LIGHT
ON IN DASH. AFTER VERIFYING, ( CAME BACK 3 TIMES AFTER
VERIFYING THE LEVEL BEING CORRECT) LEVEL WAS CORRECT PER WIS
INSTRUCTIONS, NECESSARY TO COMPLETE COMPLETE OIL DRAIN AND
REPLACE OIL LEVEL SENSOR DUE TO FAULTY INTERMITTENT SIGNALS.
REMOVED OIL FILTER AND HOUSING. DRAINED OIL PAN. DRAINED
MAIN RESERVOIR. REMOVED SUBFRAME BRACE TO ACCESS OIL
RESERVOIR//NECESSARY TO R&R LEFT FRONT WHEEL, R&R LEFT FRONT
FENDER LINER, R&R OIL SUMP RESERVOIR. REPLACED OIL LEVEL
SENSOR. FILLED WITH 6.8 QUARTS OF OIL, CHECKED OIL FLOW IN
WORKSHOP MENU IN THE DASH. FOLLOWING WIS GUIDELINES. SHOWED
4.8L MAX FLOW. ADDED REMAINDER OF OIL FOR 7.4 QUARTS.
CHECKED WORKSHOP MENU AGAIN. SHOWED MAXIMUM OIL FLOW OF 5.4L
ON SHOP FOREMAN'S TEST DRIVE. RECOMMENDED TESTING AGAIN
AFTER VEHICLE SETS OVERNIGHT TO QUALITY CONTROL REPAIR;
CUSTOMER DECLINED SECONDARY TEST TO CONFIRM REPAIRS.
I'm new to the Mercedes world, just recently picked up a 2020 AMG GT C. For the 2nd time in my life, I paid someone to change my oil. Sure enough I immediately got the overfilled measure, took it back, and it appeared again a couple days later. How are you guys siphoning some out as mentioned above? What are you using? Any pictures, details on how to do this would be great, I really don't want to waste more time at the dealer. THANK YOU!
Excess oil must be extracted directly from the oil reservoir. The reservoir is the black container located adjacent to the dipstick on the driver’s side of the engine bay.
Warm the engine to operating temperature and use a large syringe or a kitchen-style liquid transfer pump to remove the excess oil in controlled increments of approximately 1/4 quart at a time.
Reference the following post for a precise procedure on verifying oil level:
https://mbworld.org/forums/coupe-roa...ml#post9213314
Personally, I go by the dipstick. Get the engine fully up to operating temperature, shut the engine off then take the dipstick reading within a couple of minutes (a flashlight is often required for my ol' fart eyes to read the dipstick).
When filled to read about 90% towards the high-level mark on the dipstick, I find that I still intermittently (but inconsistently) get the sensor warning, usually associated with slight corners at highway speeds. In fact, I've often had such an alert on my drive to the track but, interestingly enough, it doesn't recur while on the track (and no, the car doesn't ever seem to burn oil enough to change the dipstick level). Go figure.
