Does anyone know the torque specs for front and rear swaybarlink?
Old Jul 25, 2021 | 05:38 AM
mbjj57's Avatar
amg gtc 2020 bk
Old Jul 26, 2021 | 12:47 AM
user33's Avatar
This may have what you're looking for (part of what I grabbed when installing the TiKT brake-cooling ducts).
File Type: pdf
Old Jul 26, 2021 | 02:17 AM
mbjj57's Avatar
amg gtc 2020 bk
thanks!
so it seems
torsIon bar nut torque specs for the front is 98NM and 60NM for the rear.
Old Jul 26, 2021 | 03:08 PM
user33's Avatar
Originally Posted by mbjj57
.... torsIon bar nut torque specs for the front is 98NM and 60NM fro the rear.
That was my interpretation, for the link to the suspension arm. I needed the info for the rear as that bottom bolt is used to hold the rear TiKT brake-cooling duct flange and, undoing the nut, that torque felt accurate.
Until I undid the nut and felt the torque, I wasn't entirely confident which torque was upper and which was lower. I wish MBZ was a more rigorous in their naming as they often use multiple/different names for the same item or type of item ... something you learn not to do if you want to write good software!
I did not undo the front linkage.
