Anyone have success with Cete Automotive Active Valve Control?
Old Mar 13, 2022 | 01:05 PM
Why Vegas's Avatar
AMG GTs & w204 C63
I have the renntech module and it’s night and day. You just press the “open” button and it remains full open even after the car turns off which enables a proper cold start sound.
highly recommended. Forget the CETE module.
Old Mar 13, 2022 | 02:13 PM
cryhavok's Avatar
2018 GTC Edition 50
I decided to make a quick video after running out to lunch. Car sounds amazing on cold start but I think the valve mod really shows itself on warm start. 2018 GT-C edition 50
start of video: warm start stock valve position
0:26 valves opened with module
0:42 warm start with valves open with module
1:04 valves returned to stock position
1:12 valves open with module
To me there is also a huge difference in the daily driving. The car sounds way deeper and grumbly without being too loud at normal driving speeds. I’m guessing anyone who installed a module and doesn’t see this result either has a defective module or didn’t install it correctly. The ASR/Renntech module keeps the valves open all the time and I never have to touch the exhaust button.
Old Nov 30, 2022 | 07:11 PM
dowheelies's Avatar
too many...
Can someone share the installation instructions? My Cete module showed up today but no instructions for GT in the download section on their site or in the box. Looks like just a plug in for CAN, ground ring and another plug but lord knows where I find the connections…. Thanks in advance.
Old Nov 30, 2022 | 07:30 PM
BucsFan's Avatar
'18 AMG GTC, '96 BMW 318i, '25 Ram RHO
I will PM you with the instructions.
Old Dec 6, 2022 | 07:56 PM
Timur1989's Avatar
2022 GLE63S
hey, would you mind sharing the instructions?
I am thinking of purchasing this for my GLE63S and would like to see how complex it is.
Thank You
Old Dec 7, 2022 | 02:49 AM
dllhg's Avatar
2014 cls63 a amg. 2018 AMG GTR
you just remove the passenger footwell cover. then it’s very straight forward plug and play.
I got the advanced user version. Can use app on phone. you can set so valve is open on key on or closed. you can also set different RPM you want them to open at. lower or higher. it’s pretty cool.
Old Dec 7, 2022 | 03:49 AM
  #32
mjr24's Avatar
M6 Gran Coupe
Wait, this is for the CETE module or which one? I am not aware of the CETE having any type of phone app?
Old Dec 7, 2022 | 11:35 AM
  #33
dllhg's Avatar
Yes for Cete advanced version. was $599. works really well. customizable. have mine set to be open when car turns on and stays open unless i change driver mode. sport plus and race full open. switch to sport or comfort it closes
Old Dec 7, 2022 | 01:20 PM
  #34
Skilly's Avatar
2020 McLaren 720s Spider
This is a little confusing. Sounds like the mobile app allows you to lock the valves open at start up regardless of driver setting (because driver settings aren't sticky in North America)?
Prior functioning was mirroring factory function but keeping idle when the values open increased to wide open (vs the factory limited set up).
Old Dec 7, 2022 | 01:40 PM
  #35
dllhg's Avatar
You can have it like factory if you want. Yes you can have it lock the valves on start up and all the time if you want. can set to have it go by modes from there or double tapping the esc. I found double tapping to not be consistent where the mode select always works.
here’s a pic of the ap to give
you an idea.
Old Dec 7, 2022 | 06:39 PM
  #36
BucsFan's Avatar
Thank You
Sure, look for my PM.
Old Dec 12, 2022 | 07:24 AM
  #37
dowheelies's Avatar
too many...
Thanks to BucsFan I got mine working. Works as advertised, just wish I would have seen the advanced option!! Looks to be worth the extra coin.
Old Dec 12, 2022 | 03:28 PM
  #38
Skilly's Avatar
Thank You
It will depend on MY etd, but it likely wouldn't be the same install as the GT. I did a 2021 E63S and it was very different.
Old Apr 25, 2025 | 02:51 AM
  #39
Stealthy63s's Avatar
2020 Mercedes E63S AMG
If anyone in this thread is looking for a CETE Active Valve Controller for E63s/E63/E53/GT63S/GT53, I have got one but looking to sell it as I put an exhaust on my W213 E63s and no longer need it. I'm new to this website but if any interested, feel free to reply or private message me! (I will need to figure out how to get to PM though)
