GTR PRO fender liner
I have sent renntech a msg regarding fender housing.. i might be able to use the current liner (cut) and use renntech’s fender housing
That’s what these are for. You can use your regular liners and make them usable with the fender vents. I have a 2016 GTS.
i already have the carbon fiber louvers… lets see if renntech sells only the housing
E55, Z06
amg gtr pro front fender...
E55, Z06
Okay so if we just cut the top of the fender and drop the Pro fender vent in place that’s not enough right? The liner seems like it has little tabs or something where the fender vents attach?
Amg gtr pro fender part #
left
1908804701
right
1908804801
left
1908804701
right
1908804801
bhamcarnut (06-12-2022)
This is the piece that Renntech sells. Very well made and almost looks OEM. To use this, you will need to use Renntech’s louvers unless you cut the tabs off other manufacturers louvers. I’m sure tab holes could be cut into the fender and these adapters to fit as well. You also cut into the OEM fender liners so these are actually working. This setup is very similar to the GTR Pro but causes ulcers knowing you have to cut into fenders. Lol.
E55, Z06
Christian
mbjj57 (06-13-2022)
