Normal to always feel the road in my steering wheel?
Subscribe
Aug 24, 2022 | 08:50 PM
Nm….
Reply 0
Aug 24, 2022 | 09:07 PM
From your description, no that doesn't sound normal. A constant pulsing is not what one understands of steering feel and feedback. The GT has a hydraulic steering vs many other cars including M cars have electronic power steering these days, and modern M cars aren't exactly known for good steering feedback anymore. But steering feel and sensation is essentially torque feedback through the steering rack that tells you what the front wheels are doing. If they are loosing grip you can feel through the steering that it's becoming light and if the wheels are working harder to turn you can also feel that in the steering effort required. You may also feel the wheels following minor ruts in the road, so external forces that make the wheels slightly deviate from straight can be felt in the steering wheel. A steering that lacks any feedback will essentially feel like a video game. You turn it, but you can't really tell what the front wheels are doing and how much grip they have. I suppose this is a bit hard to explain, but hopefully it makes sense. A pulsing or vibration in the steering wheel would be something else.
Reply 0
Aug 24, 2022 | 09:33 PM
Sounds like you're describing tramlining as Superswiss describes.
Reply 0
Aug 24, 2022 | 10:28 PM
K
Reply 0
Aug 25, 2022 | 12:55 AM
Quote: No, I definitely don’t mean following ruts in the road so I don’t think it’s tramlining.
This is definitely feeling the road surface regardless of smooth or crappy. My steering wheel isn’t moving left or right per se….it’s just a constant almost hum in the steering wheel.
Yeah that doesn't sound right. You should not feel the irregular surface of the road in the steering wheel in the form of vibration or pulsation. You'll feel that through the suspension and the seat, depending on how rough the road it.
Reply 0
Aug 25, 2022 | 04:40 AM
What tire pressure are you running?
Reply 0
Aug 25, 2022 | 07:10 AM
And one last "longshot" - It's not lane assist on?
Reply 0
Aug 25, 2022 | 09:46 AM
Quote: And one last "longshot" - It's not lane assist on?
My instantaneous thought is that he is describing Lane assist. Drive in the middle of a parking lot and see if the problem goes away. If it doesn't, then you need to take your car in for service right away as your lane assist is probably faulty. If it only happens on a road, then you need to really check your driving pattern and see if you are hugging either the right line or the left line of the lane you are in. If you hug the lane's edge your steering wheel will vibrate the entire time basically telling you to center your car.
Reply 1
Explore
Aug 25, 2022 | 10:41 AM
Quote: My instantaneous thought is that he is describing Lane assist. Drive in the middle of a parking lot and see if the problem goes away. If it doesn't, then you need to take your car in for service right away as your lane assist is probably faulty. If it only happens on a road, then you need to really check your driving pattern and see if you are hugging either the right line or the left line of the lane you are in. If you hug the lane's edge your steering wheel will vibrate the entire time basically telling you to center your car.
Agree with you....Happened constantly when I first got my car. I shut off lane assist and have not used it since. More annoying than a safety feature if you are an attentive driver.
Reply 0
Aug 25, 2022 | 11:33 AM
Sound like lane assist or tire pressure too low...
Reply 0
Aug 25, 2022 | 02:36 PM
Quote: Sound like lane assist or tire pressure too low...
Hey guys, 110 percent not lane assist. I don’t have the drivers assistance package.
Hmm….just checked and my cold PSI is 36? That’s too low isn’t it?
Reply 0
Aug 25, 2022 | 02:46 PM
Don't know from the top of my head what the recommended tire pressures are for the GT, but I believe max load is 36f/39r. This would actually be too high for an unloaded car with only you as the driver. Check the placard inside of the fuel door. It has all the pressures listed for different speeds and loads. You wanna use the normal load pressure for most of your driving. It's lower than what you find on the door jamb. The latter is also max load and top speed only in North America.
Reply 0
Aug 25, 2022 | 02:58 PM
Quote: Don't know from the top of my head what the recommended tire pressures are for the GT, but I believe max load is 36f/39r. This would actually be too high for an unloaded car with only you as the driver. Check the placard inside of the fuel door. It has all the pressures listed for different speeds and loads. You wanna use the normal load pressure for most of your driving. It's lower than what you find on the door jamb. The latter is also max load and top speed only in North America.
Bah, I’m a moron. I accidentally posted this in the coupe section. I actually have a 4 door coupe. It’s 38 rear and 39 front for cold PSI. I think my tires are warmed up currently….so I did 42 front and 41 rear (assuming 3 PSI from cold to hot).
Reply 0
Aug 25, 2022 | 03:21 PM
EDIT: still there with higher PSI. If anything, it’s more pronounced now
Haha...that's what happens when manufacturers call something a coupe, when it really is a sedan. Anyway, AWD does change things a bit. There's a level of impurity in the steering with the front wheels also handling propulsion instead of just steering the car. Although, 4Matic+ sends almost 100% to the rear under normal traction situations. But you could eliminate AWD from the equation by putting the car in drift mode and see if it makes any difference.
Reply 0
Aug 25, 2022 | 08:56 PM
Take it to the dealer.
Reply 0
Aug 25, 2022 | 10:34 PM
Ok
Reply 0
Aug 25, 2022 | 11:24 PM
Quote: They found that 2 of my wheels are bent. That definitely sucks. Can forged wheels be straightened? I keep hearing different answers.
Yep that would do it. I did have a forged wheel straightened, but it wasn't the drum that was bent, only the lip. They seemed to be able to do it, although it's not perfect. Straightening wheels is never perfect, but hopefully after road force balancing it'll be round. Tires are not perfectly round, either. You may not even need to straighten the wheels depending on how much they are bent. They may be able to compensate for the bend during road force balancing.
Reply 0
Aug 26, 2022 | 12:31 AM
Thanks.
Reply 0
Aug 26, 2022 | 02:23 AM
Quote: This has been really frustrating. I bought this car CPO'ed 2 weeks ago and it's become apparent they sold me a car with 2 bent rims and a poorly refinished bumper and fender (as this vibration has been there the entire time and I haven't hit any potholes). I'm quite honestly regretting coming back to Mercedes at this point....the whole experience has been ****ty. I might push for them to unwind the deal and go back to BMW......they should have never CPO'ed this car. It's not a 2014 C300.
I can understand the frustration, but go ahead and google CPO bent wheels. The first search result is a thread on bimmerpost, scroll down and there are threads on bimmerfest, z4-forum and so on. CPO is an extended warranty not much more, but like the factory warranty it doesn't cover wear parts. Wheels are wear parts. Not sure what's going on with your bumper and fender, but on that you might have recourse if it hasn't been repaired to certified standards.
Reply 0
Aug 26, 2022 | 03:28 AM
Quote: I can understand the frustration, but go ahead and google CPO bent wheels. The first search result is a thread on bimmerpost, scroll down and there are threads on bimmerfest, z4-forum and so on. CPO is an extended warranty not much more, but like the factory warranty it doesn't cover wear parts. Wheels are wear parts. Not sure what's going on with your bumper and fender, but on that you might have recourse if it hasn't been repaired to certified standards.
Reply 0
Aug 26, 2022 | 03:52 AM
Quote: Front bumper and fender were refinished really badly....like literally they forgot to put clearcoat on parts of them and it's just a base coat in 2 different whites (seems like the part they didn't clearcoat is almost just bare metal). There is a larger than normal gap between the headlight and hood on the damaged side than the other side (which isn't normal). I don't think the dealer I bought from did the work but they definitely DID NOT inspect the car per the CPO checklist (which clearly calls out that they need to check the paint, signs of structural damage, etc.). I mean, they detailed the car before.....they saw this stuff. They just ignored it. Ultimately, that puts this on them. It took the estimator at the dealer I went to about 10 seconds to determine the front bumper had been refinished (I originally went in there thinking it was just the fender). I've been given $3k estimates on this work to basically refinish the fender, bumper, and blend in so everything is done like it should have been.
Just to contrast....the front doors have some minor rock chips on them but stuff like that I am totally cool with....it's normal wear. I had that on my F90 M5 within weeks of buying it new because of how sticky the tires are. That's my point.....refinishing a fender or bumper here or there is fine....ASSUMING it's actually done up to MB spec. This looked like it was done at Maaco. I was not expecting a mint car. However, I was expecting a car that had properly finished bodywork (the first rock chip on the un-clearcoated fender here in CHI this winter will start that fender rusting within days) and wheels that 1) should have been repaired or 2) replaced.
As for the wheels, sorry, I have to put that on them, too. They could not even balance 2 of the wheels today because of the bends. A simple test drive about 60MPH would have revealed these problems. Not only that, it's a safety issue. Plus, I'm pretty sure Mercedes states bent wheels must be replaced (I think every manufacturer states this but we all know that wheels can be repaired in most cases). I mean, the CPO states there can't even be scratches on the wheels.....pretty sure they would have an issue with bent wheels.
No one spends 6 figures on a CPO and expects they are going to have put thousands and thousands more into it because of missed work. Oh, and Mercedes Me is an absolute joke (well...I think.....considering it won't even work and no one seems to know why at tech support). Just a mess.....makes Mercedes look really bad. I buy pretty much only $100k plus cars....they don't seem to want to keep my business. Let's put it this way....had I know this car had these issues, I wouldn't have looked twice at it.
I am in discussion with the dealer and they seem like they want to work something out....I would rather not have to involve corporate in this. It's just been a stressful few weeks....like I said, this car did not meet MB specs for CPO as it was sold. I've heard corporate actually hammers down pretty hard on stuff like this......it might be one thing if we were just talking one bent wheel overall....but not multiple AND multiple refinishing of panels. Let's just be honest....if I bought this car elsewhere and brought it to this same dealer for possible trade-in, they would ding me for every one of these same things. Sorry, venting...
Definitely not a pleasant experience, but I have to ask. Did you not test drive the car? If you think the vibration should have been noticed on a test drive, why didn't you notice it and brought it up before buying the car? Same for the paint. Did you not inspect it before buying it? Unfortunately, CPO is more show than substance and it's not just with MB. Dealerships don't take these inspections all that serious. They rather get paid for the repairs through the warranty than spending a lot of time on the certification. As for Mercedes me, it has changed completely with model year 2019. What year is your car? The new system is called Mercedes me connect. Different app, different everything. Works very well on my car. Just renewed for another year as the initial complimentary 3-year subscription is gonna expire next month. Some of this takes a bit of due diligence before buying the car to know what to expect. If yours is a 2018 or older than you are on mBrace which is end of life and several services have been terminated already. Can't renew live traffic anymore for example. The facelift GT 4-door is now also using MBUX and not COMAND anymore. Technology moves on unfortunately.
Reply 0
Aug 26, 2022 | 07:45 AM
Wow. With the "key information reveal" (wrecked car and not even a GT) - makes me wish I hadn't wasted time on this thread. Maybe you could get it moved out of GT and edit your first post to include the real / key information so others don't waste their time reading through all of this. It's like asking a bunch of questions about your pet Fido on a dog thread, and then only revealing 10 long comments later that Fido is an elephant with a broken leg. Haha.
Reply 1
Aug 26, 2022 | 08:19 AM
What is the year and model of this vehicle? Is it or is it not an AMG GT coupe or roadster?
Reply 0
Aug 26, 2022 | 11:19 AM
Shady Chicago dealerships...the worst. And those Illinois roads prob bent those wheels.....horrible. Hope you get it sorted out.
Reply 0
Aug 27, 2022 | 07:56 AM
Quote: Shady Chicago dealerships...the worst. And those Illinois roads prob bent those wheels.....horrible. Hope you get it sorted out.
I agree with shady. As a buyer you only have to be screwed once by buying from a state that can wash titles. Never ever buy a car from Illinois or other title washing states without a thorough third party ppi. This state can take a total loss and make the title clean…. Complete fraudulent bs state.
Reply 0
