GTR Alignment Shim Info
After reading all the posts I could find, it's still unclear whether 2 boxes or 4 boxes of shims will be required (because there are posts with both claims).
My dealer has supplied the following info:
A 197 357 06 00 is listed as the correct number in our catalog for the shims. It lists qty 1 each for each corner (4 total for the vehicle).
He also put through a request for sizing info and followed up with this info (I have a great dealer!):
... unfortunately they were unable to provide me info for the size of each of the shims. They understand that it is 1 kit per corner, and includes the plates listed below.
A1973570600 kit includes the following adjusting plates:
A1973570142 ADJUSTING PLATE / 1 Quantity 4
A1973570242 ADJUSTING PLATE / 2 Quantity 4
A1973570342 ADJUSTING PLATE / 3 Quantity 4
A1973570442 ADJUSTING PLATE / 4 Quantity 4
A1973570542 ADJUSTING PLATE / 5 Quantity 4
A1973570642 ADJUSTING PLATE / 6 Quantity 4
A1973570742 ADJUSTING PLATE / 7 Quantity 4
A1973570842 ADJUSTING PLATE / 8 Quantity 4
A1973570942 ADJUSTING PLATE / 9 Quantity 4
QUESTION:
For those of you who've done similar with a GTR Pro, can you confirm whether 2 or 4 boxes of shims will be required?
For those who've done similar with any other GTx model, it'd also be great to record that information for future use ... please just be sure to indicate exactly which model(s) you're posting about.
Supertanch
Your camber is more aggressive than others I ran across, can you elaborate on your tire wear characteristics? Info like the following would be great:
- type of tires if not Cup 2 MO
- guesstimate on non-track vs track usage
- inside vs outside tire wear ... ideally a comparison for non-track vs track usage
- did you use the OEM settings for toe-in
- anything else you've learned that might be useful in relation to this camber setup (e.g., track performance improvement)
(slow response on my part because I was away squeaking in another end-of-season track day ... $;-))
Supertanch
I normally run two types of tires depends on availability/mood
, the BS sized cup2R (285/35/19f, 335/30/20r) or Nankang CR-S (stock size).- guesstimate on non-track vs track usage
80% track usage, the non track usage are mostly driving to/from the track, the 3 tracks near me each is about 60-100 miles one way, so it definite has a bit of HW miles.
Given that I have almost only track usage, the inside/outside wears are pretty equal for the most of the cases - I do push on track so the camber is mostly used for that, FWIW the current setup of my car is more on the loose side (I also run 0 toe) where I tend to use the rotation to fine tune the speed of each corner.
0 toe for fronts, 0.06 total for rear.
The camber has really helped me on prolonging the life of the tires, and increased mid corner stability of the car. It took me about 1 year (the car now has > 25 track days) to find out the balance of the setup and now it's kind of sitting at a sweet spot for my driving style. Like any other setup, it does require you to tune, compare and analyze after each track day to find the right balance, and also according to your local tracks' condition. The Norcal tracks have a lot of mid speed on camber corners so the extra camber definitely helped for me.
Enjoying the tuning! the key learning from me is to tweak only one thing at a time, so you can have a good baseline comparison to improve upon. Moving too many variables actually complicate the equation.
My main goal is to extend the life of the tires, in particular to enable me to run lower pressures without killing the outside edge immediately. I found that I need to keep the Cup2s at 35 psi or above or else the outside edge gets destroyed very quickly. Of course that means that, even with careful management, pressures will sometimes creep up to 38 or 39 psi during a 20 min session on hotter days. At about 37 psi they start to lose grip fairly rapidly. One day I targeted 34 psi and put about 3x as much wear on the outer edge so have been living with the trade-off towards longer outside-edge life (it's the Scottish blood in me, I guess).
The grip level actually reduced on corner exit a bit (tail happy) due to the static rate increase in the rear, given your local track has more twisty/lower speed cornering I would suggest you to use the stock setting to make the weight transfer more gradual.
I was more thinking of stiffening up the front, but don't want to increase understeer ... and I have a nagging feeling that, with all the suspension interdependencies, the AMG engineers/testers probably achieved a pretty optimal balance so it'd likely be better to increase both front and rear stiffness if wanting to reduce body roll. Then the question becomes "would the ride quality become too torturous running to/from the track?" ... it's already border-line with track-ready shock settings.
Did you play with the front sway-bar, at all?
I've already discussed (with my dealer) the idea of loading the driver's seat with about 150 lb (I'm skinny!) when the alignment is being done and they've indicated this can be done.
My question is "is this a worthwhile/meaningful thing to do or is it of negligible (or maybe even negative) value?"
BTW, since the 2 "short 'n twisty"/lower-speed tracks I attend are opposite-turn biased (one is CW and one is CCW), I'm aiming at a same-each-side camber setting as opposed to canucklehead's track biased setup.
, especially on double-wishbone setup. And yes use the balanced alignment spec is the best, unless you have a very biased track. Giving you also drive on the road, it will help on the tire wears as well.
- I asked for about -2.7 deg front and -2.5 deg rear
- I got -2.75 deg on both front and rear (somehow things didn't get communicated correctly ... unusual, but it can happen)
- at first it seemed fine, but as I went to tracks that had higher-speed straights, I found that the car was getting increasingly "squirrely" under hard end-of-straight braking ... fine at about 180 kph, noticeable at about 200 kph and getting bothersome at about 215 kph (I suspect that it'd be dangerous at over 250 kph and might be wanting to "swap ends")
- the as-delivered front-to-rear difference on my car was about 0.47 degrees and people have reported using a front-to-rear difference of about 0.2 to 0.4 degrees
I put a new set of tires on before my most recent track day that also involved about 9 hours of driving to/from the track. Once I measure the tire wear across all the tires, I'll make a decision about how much to back off the rear camber setting (and update this posting).
Curious to learn what's your tire wear shows, I generally experience that the rears lasts almost twice as much as the fronts under the track alignment specs..
For tire wear -- Cup 2 MO, new prior to both trips.
2022 : standard camber: On-track time (at Area 27) with low aggressive driving (1st time w/GTR at track) was about 1.25 hour and outside temps were 25-35 deg C (77-95 deg F). The in-car "air inside tire" readout showed temps hitting a max of 100 deg C but mostly I was on target at about 75-80 deg C with pressures at about 33-35 psi. Off-track driving was about 950 km (590 miles) with temps on the return drive ranging from about 22-32 deg C (72-91 deg F) with in-car "air inside tire" temp readout showing about 30-40 deg C and pressures of about 34 PSI. Temps were 2-5 deg C cooler on the drive to the track with rain for about 2 hours of the drive. The drive includes about 1.5 hours thru rocky mountain foothills/mountains with lots of (fun when dry) twisty parts ... but had rain during the drive to the track so was taking it _very_ easy (Cup 2s are dangerous in the wet!).
2023 : high camber: On-track time (at Area 27) with medium aggressive driving (still learning track) was about 1 hour and outside temps were 30-33 deg C (86-91 deg F). The in-car "air inside tire" readout showed temps hitting a max of 100 deg C but mostly I was on target at about 75-80 deg C with pressures at about 34-36 psi. Off-track driving was about 950 km (590 miles) in temps ranging from about 25-32 deg C (77-91 deg F) with in-car "air inside tire" temp readout showing about 35-40 deg C and pressures of about 34 PSI. The drive includes about 1.5 hours thru rocky mountain foothills/mountains with lots of (fun when dry, it was) twisty parts. Corners with complete visibility typically run at 2x posted corner speed with others at 1-1.5x posted speed, depending upon visibility (I'd guess nearly always under 1G lateral, so appropriately aggressive for public roads).
Here's my tire-wear data ... the two inside/outside edge measurements are at the most wear point on the outer edge then inwards on the slope of the wear block (a little subjective) the single measurement is just the inwards one. The middle numbers are across the circumferential groves.
High-camber alignment data:
I was thinking of backing off the rears to -2.5 degrees (which was my original request), going less towards -2.4 based upon the actual shims.
Does anyone have any thoughts on this rear-camber setting and/or the toe-in settings?
Your rear toe looks fine, it's 0.11 total (front is zero toe) so it's well within good range, also your rear/front cambers are both -2.4. So the braking behavior you experienced were most likely not due to alignment.
Any wheels having slightly unbalanced weight?
I always started around 26 psi and aimed for 32/33 psi hot.
Nope, the local shop I get to swap always gives me a "zero feel me" balance ... and I always lay some very sticky and temp-resistant fiber tape over the weights to ensure they stay on.
BTW, I think I've mentioned it before, but I did create this web page that can help set initial cold tire pressures when arriving at the track:
http://car.dnsalias.com/car/startingTirePressures.jsp (note this is NOT https)
It's self-contained javascript code so, once the page is loaded, it will run without any internet access (and you can easily see what it does by examining the page source).
After comparing to the standard-camber wear readings (which I've added to the posting), my thoughts about tire wear were the following:
- There's decreased outside edge wear ... aside from some better handling, that was a primary goal for the high-camber alignment.
- There's increased inside edge wear. That was expected and is "the worst" in this case due to the 9 hours of highway driving to get to/from the track. This track day also had minimal on-track time <grrrrr>.
- The high-camber alignment was done with my previous set of Cup 2s and what I saw after 2 VIMC and 1 Mission trackdays, where the to/from to-the-track driving is about 1 hr 20 min each way, was much less inside edge wear. It appeared that the inside and outside edge wear was very balanced with that amount of street driving (including my normal weekly "keep it lubed" runs).
So, tire wear aside, this still leaves me with the high-speed braking "squirreliness" issue.
Cambers are -2 deg 45 min ... so -2.75 deg -- no?
LF = -2.6 T=0.01
RF= -2.7 T=0.01
LR = -2.2 T=0.05
RR= -2.3 T=0.06
For reference this is super stable at Area 27.
End of main straight speed ~238km/h, hard late brake into turn around 75', half way between the 100 and 50 marker. Super stable. With a bit more time I could probably brake a bit later and take that turn with more speed. Best time 2:15.
Also, do you crank your wing all the way up for Area 27 (assuming you're still using the stock wing)?
Serious lap time, BTW. I'm way slower at this point (always slow at learning a track).
