jerking when pressing on accelerate pedal
Need some opinion, when i accelerate the car jerks sometimes on all modes. there is no warning lights and not sure this is normal for an AMG cars. Anybody have this issue?
tks for the info. its quite a relief knowing its not a major issue.
You are right again. Mostly happens when im not using the pedal shift. Your advice really make sense. Thank you so much for the amazing info superswiss! These really helps.
You may be correct, but tbh after an OEM break-in, winding a car out on a road course multiple times is going to "open it up" pdq.
Pretty common for the DCT to ‘jerk’ when it changes from 2nd to 1st at very low speeds when coming to a stop. Go ahead and pull the left paddle at around 10 mph so that the gearbox changes into first when the engine is pulling slightly higher revs, and it will smooth out the change greatly. You can still leave the car in ‘D’ or Auto mode as it will revert back to Auto after a few seconds even when you initiate a solitary manual change via the paddles. I did this pretty much all the time and it became second nature.
