AMG GTC Roadster Passenger Side Water Ingress
Old Feb 6, 2023 | 06:21 AM
sxemf's Avatar
AMG GTC Roadster
Hi All,
I'm from the UK and I bought a very low mileage GTC Roadster 8 months ago (now 9000 miles) and it's been a wonderful car to own with zero problems... until this weekend. For some reason, the passenger side carpet is soaked (but not swimming) and I was looking to diagnose. My thinking is that it's either:
  1. Water ingress from a pressure washer when I got the car cleaned. This isn't something that's been a problem before, but I understand that just the wrong angle could cause a problem.
    • Has anyone else had this issue and know where this may have come in from?
  2. Water ingress via a blocked drainage hole.
    • Does anyone know where the drain holes are in the front of the car that might lead to overflow into the footwell? Any pictures would also be welcome.
  3. The worst scenario is that it's an issue with the AC/Heater unit. At the moment there are no water tide marks (I've seen white tide marks in other cars when the AC/heater unit has been the issue).
    • Are there any known issues with the AC/Heater circuits that might cause this issue in the GTC?
I would really appreciate any help on this issue. I have seen posts on water ingress to the boot/trunk, but nothing in the front.
Many thanks in advance
Old Feb 6, 2023 | 06:55 PM
California John's Avatar
2022 AMG SL63
Originally Posted by sxemf
Hi All,
My first guess is that it is the pressure washer. Iif I remember correctly, sometimes the drain line for the A/C can get plugged up. Both are worth looking into.
Old Feb 7, 2023 | 03:16 AM
sxemf's Avatar
AMG GTC Roadster
Thanks for your reply. Do you know where to look for the drain line for A/C?
Old Feb 7, 2023 | 12:29 PM
Wolfman's Avatar
Super Moderator
Here are a couple of related threads. Hopefully this helps. I have seen a few threads from the UK. Good Luck!
https://mbworld.org/forums/coupe-roa...iss-furia.html
https://mbworld.org/forums/coupe-roadster/792046-warning-all-convertible-owners.html
https://mbworld.org/forums/coupe-roa...ml#post7950617
Old Feb 8, 2023 | 04:08 AM
sxemf's Avatar
AMG GTC Roadster
Thank you. I did read these, but they all seem to relate to drain holes at the rear of the car. I'm looking for the front drain holes or A/C drain. The car will be going in for a B1 service soon and whilst it doesn't state on the service docs that the drain holes should be checked, I'll ask them to take a look.
