GT problems when modified?
They tested the PDK on a 2014 Turbo S by launching it 50 times as a sort of anniversary stunt or something. Not a single issue. They could have kept going.
There is NO WAY you can replicate the Black motor. Among many other additions the Black has a flat plane crank. When you have a chance, read up on both platforms and you’ll see why it isn’t possible.
Go to Weistec or Renntech for one of their proven packages and you’ll be happy.
Good luck.
(This is some of that "poor feedback." I admit it in advance. But unless this guy drives on the Autobahn and has a few years' experience and a professional racer, I don't want to be on the same continent with him wheeling around 800 HP.)
To OP: I have a stage 2 tune and set up on my GTR and, while only use the car to track, even that much power (far less than 800hp) is hard to use reliably with RWD. My advice is to go with a different car if you're chasing power and speed; you'll honestly have a better time modding a Nissan GTR for that purpose. For what it's worth, my original plan was the get the GT R built to the same numbers you're looking for, but decided to stop at stage 2 and get a manual MK5 Supra for that purpose. The modding community, part availability, and price seem much more conducive to chasing ponies on the Supra than on the AMG.
800hp anything is really expensive, but I mean I'd rather have an 800hp Shelby or Z06 than an AMG. A 577hp AMG is a far better experiance than either. Unless you have a specific need to hunt down hypercars that will still weigh less than you by 1000+ lbs theres not much out there that can take on a tuned AMG car with tasteful mods.
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
The GT class, even with its pinnacle Black Series, aren't designed for brute force pulls off the line. Sub 3 sec launches is not why someone gets this car...track it, and you learn why. That is where these things shine. There are some great options from tuners to get there in HP range, but you will pay $50K do dial it all in with Turbos, tune, DPs and exhaust and it would still struggle with a sub 3 sec launch - nanny mode comes on even with a stage 1 set up! And track performance improvements would be moderate unless you start considering aero and weight drops. I know you didn't call out launch specifically Im guessing there is some sort of objective in beefing it up to that level of HP.
If you want bragging rights or a 1/4 mile killer there are better choices (hint AWD platforms). If you want a highly capable track car that will daily drive, you're in the right place.
Hey Skilly, did you have a chance to track the 720S? any comparison points vs the GTR?
You missed an opportunity;
7k-Mile 2019 Mercedes-AMG GT R for sale on BaT Auctions - sold for $155,000 on July 5, 2023 (Lot #112,558) | Bring a Trailer
https://bringatrailer.com/listing/20...es-amg-gt-r-2/
Maybe there will be another.
Maybe cthere will be another.
please listen to what happened to me before you mod ur car. mine is a 2015 GTS and tuned the car to stage 2. remap the ecu, bmc filter, catless downpipe, full custom exhaust system. results 562whp - 665hp/779nm torque. after a month driving it the car was misfiring. so took it to the mechanic and diagnose the car and the fault code P036600 related to engine timing and position of camshaft for cylinder bank 1 has malfunction. another fault code P001764 position camshaft cylinder bank 1 is implausible relative to the position of crankshaft. mechanic says have to drop the engine and open the valve cover. so they did and found out the camshaft adjuster have twisted. have to replace all 4 camshaft adjusters. how did this happen? according to the mechanic the torque was to much that the camshaft adjuster twisted. cost estimate plus labour USD6500. for those of you have not seen a camshaft adjuster the 1st picture below shows it.
to cut the story short dont mod ur gts or maybe im just the unlucky ones or maybe the remap torque was to much. the camshaft adjuster could not take the extra torque. u want to mod a car get a nissan gtr.
How’s your car doing now? Are you still modded? Since you had to go into the engine did you upgrade anything else?
GTS at these prices are for if you're a Porsche contrarian and you want a less proven engine/transmission combination
