2019 Raw Fuel Leak
Dealer isolated the issue to the rigid fuel line part # 190-470-16-00-64 priced at $58. When I physically looked at the fuel line it appeared to be a low quality rigid plastic line with press-fit connections at both ends.
I have owned 9 MB's in my lifetime and have never seen this. Please share if you've had a similar experience and if the replacement held up over time.
One of my frustrations was the inability to put the car in neutral (without starting the engine for obvious reasons) and roll it back into the driveway. Looked everywhere and it seems like there is no way to temporarily put the transmission in Neutral.
Thank you.
Thank you.
There is a 2019 MB Bulletin about it (see attached PDF), which fixed the issue for me.
Hope this will help.
In my case, the leak was visible (Dripping) when the car is off and it was literray spraying fuel when the ignition was in the on position and streaming when turned on.
Thank you
Huge thank you goes out to Fletcher Jones Newport Beach for addresing the issue professionally and expeditiously. Service Advisor Ruben Soltero gets two thumbs up along with his colleagues for walking me through the process, introducing me to Sean the AMG GT tech and Tom the shop Foreman for explaining and showing me the compromoised area under the car while on the lift.
Ordered the least expensive OE parts from that bulletin, from this place.
I will follow up with a video, when I do the job.
https://www.mbpartsource.com/account/signup
