Some basic info in the article here.
https://www.autoexpress.co.uk/merced...p-straight-six
If that is true, then it leaves the GT63 Coupe 2 doors as the only V8. That s great, it really makes it stand out. They didn’t do that in the SL and I feel it’s all a mess there: V8 for both 53 and 63 models. And a 4cyl engine as a starter. For what is supposed to be a special car. I hope the 4 cylinder doesn’t ever come to the GT Coupe, just to keep it apart from the lower models out there.
”The 53 should come with the 3.0-litre straight-six mild-hybrid from the CLE 53, tuned to 449bhp and 560Nm of torque. We expect a 0-62mph time of 3.9 seconds and a 183mph top speed.”
superswiss
close
- Join DateNov 2018
- LocationSan Francisco Bay Area
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive2019 C63CS
Liked:5,342 Times in 3,643 Posts
You're confusing some things. The V8 is in the GT 55 and GT 63, just like it is in the SL 55 and 63. The 53 (not 55) is the next lower entry model which gets the straight six just like the recently unveiled CLE 53. It's also mild hybrid. There's also a GT 43 coming with the same 4 cylinder engine as the SL 43.
superswiss
close
- Join DateNov 2018
Also, the strange thing is that the 4 cylinder in the 43 models is now the hand-built OMOE M139, so it's a true AMG engine, whereas the straight 6 in the 53 models is a tuned MB engine and not a hand-built AMG engine.
Quote:
Yeap, you are correct… I got confused..Originally Posted by superswiss
still, if the info is real it’s a better choice then the 4 cylinder engine
superswiss
close
- Join DateNov 2018
See above. That depends. The 4 cylinder is an actual hand-built AMG engine, whereas the 6 cylinder is a tuned MB engine and not hand-built and designed by AMG.Originally Posted by Raulr
Yeap, you are correct… I got confused..still, if the info is real it’s a better choice then the 4 cylinder engine
W205C43PFL
close
- Join DateDec 2019
Liked:6,323 Times in 5,487 Posts
Will be interesting what actual difference performance wise is there between the M256 from lets say the 2019 E 53 and now the M256... M in the 2024 CLE 53
Wolfman
Super Moderator
close
- Join DateMay 2002
- LocationLand of 10,000 lakes
- Vehicle(s) I driveAMG GTC Roadster, E63s Ed.1, M8 Comp. Coupe
Liked:3,675 Times in 2,253 Posts
Quote:
The 53 models have been anemic in the past but MB has juiced up the engine a bit. More HP and torque and a 12 sec. overboost feature. I like the V8 though...Originally Posted by W205C43PFL
W205C43PFL
close
- Join DateDec 2019
Quote:
For sure, I mean, at the end of the day still going to be better than a four cylinder. Cylinders count, I am not writing off the capability of the M139 but from my eperience the clyinders does count for smoothness and effortless driving/passing on the highway. Originally Posted by Wolfman
Explore
