quickjack and GTR lifting
I have a quickjack 5000 and I bought the 6' extension kit to lift the GTR. I am wondering what do people use as the rubber jack point. The rubber blocks that came with quickjack are too tall to be used with the extension as there is very little clearance.
JSwan724 (05-21-2024)
GTConn (03-05-2024)
You don't want to stack them. Shouldn't need to anyway... Because you have to use the extension, the only thing you can do is pull the car up on ramps or boards to get the extra clearance needed. We have the Quickjacks 7000 and have lifted the car multiple times using this technique.
These are also an option:
The low profile service ramps were a pain to use, and the car flung the rear pads backwards when I was trying to drive up on to them. I ended up using a table saw to just trim the rubber blocks that come with quickjack. Make sure to use a respirator as cutting the rubber blocks with the table saw makes a lot of toxic smoke.
GTConn (05-21-2024)
