Transmission shifts up extra gear in manual mode
Old Mar 14, 2024 | 10:08 PM
MercAMGgts2016's Avatar
AMG GT S
2016 AMG gt s
in sport plus manual mode. When I use the paddles to shift up sometimes it jumps an extra gear.
so 1 to 3 and 2 to 4 instead of 1 to 2 and 2 to 3
any thoughts on this?
Old Mar 15, 2024 | 12:39 AM
superswiss's Avatar
2019 C63CS
First off, are you in permanent manual mode or temporary manual mode? If you don't know what the difference is, temporary manual mode is entered if you just start using the paddles. Permanent manual mode is entered if you press the M button in the center console.
In temporary manual mode the transmission still automatically upshifts near redline, so if you are winding it out and then try to shift manually you may catch it late and it registers your manual upshift as a second upshift, after it did the automatic upshift already.
If you are in permanent manual mode and this happens, then you may have a worn out shift paddle, which does happen. This can cause the switch to bounce and making contact multiple times making the transmission think you pressed it twice in rapid succession.
Old Mar 15, 2024 | 11:16 AM
Blacksport350's Avatar
Formula Mazda, Beast Junior...400HP 135i
I think Superswiss nailed it. I have had a paddle problem on another car cause this. The same with not being in the true manual mode by engaging the manual button.
Old Mar 15, 2024 | 11:56 AM
AMG GT S
Thanks for your replies
I always run in permanent manual mode.
I agree it could be a worn paddle shifter
Will need to get it looked at
cheers
Old Mar 15, 2024 | 03:32 PM
cheers
Try a more deliberate "pull" on the paddle in question and also try to keep it from snapping back as that may help avoid that for the time being.
Check these out. I can't recommend the JQ Werks magnetic paddles more highly. I have not used them in the GT R but I have used them in Porsche/Audi applications and they are fantastic. They shouldn't be hard for you to fit yourself. You should email them for the correct ones for your car if you decide to go that route.
https://jqwerks.com/collections/mercedes-benz
Old Mar 17, 2024 | 12:20 AM
AMG GT S
Funny thing to add, this problem seems temperature specific as it seems only to occur at around 10 degrees (50 Fahrenheit)
Old Mar 17, 2024 | 05:34 AM
sevenhead's Avatar
2018 Mercedes-AMG GT R Evo
When in manual mode I noticed that the dash will indicate the gear and suggest that you upshift, ie, like the old upshift light used in cars back in the 80's. Don't know if your car has that but my 2018 GT R does.
Old Mar 17, 2024 | 03:40 PM
foooo's Avatar
GTS, GLE63S, G55
My car has the exact same problem. I've deduced it to be mechanical switch bounce as superswiss mentioned. The mating contacts on the switch are getting worn out and are subject to variations in temp / humidity, that's why you are seeing it happen at different rates. They should have used optical switches for the paddles
-foooo
Old Mar 18, 2024 | 12:57 PM
57 GTR's Avatar
2018 Diamond White GT-R
How many miles are on these offending cars?
Old Mar 18, 2024 | 09:00 PM
foooo's Avatar
GTS, GLE63S, G55
40K on mine, 2016 GTS
-foooo
Old Mar 18, 2024 | 09:47 PM
AMG GT S
39k miles
