Make your own front plate holder for GT series
Old Oct 5, 2025 | 02:26 PM
user33's Avatar
This is from the Picture Thread (didn't want to get too far off-topic, in that thread) ...
Originally Posted by untamedd
got my first ticket today for no front plate after 6 months. The first thing the guy asks me is so how many times have you gotten this before so lets see i started getting pulled over more frequently too now.
Rather than use any of the gawdy commercial front-plate mounts I was able to find (the OEM one being butt-ugly ... shame, AMG!), I purchased some thermo-plastic sheet from Mr. A. and made my own. While mine's specific to the GTR Pro, this may give others some ideas for something that's more in tune with the car's styling. Although it blocks the lower louvers a bit, so does the OEM euro-plate holder and I've not had any over-heating problems on track.
Old Oct 5, 2025 | 06:13 PM
untamedd's Avatar
2019 AMG GT R
Not bad thanks I had a similar idea but i was thinking about making it tilt outward instead and also how it would cover up that lower part but good to hear you say it didnt have an impact.
This way might be better however since it only touches the plastic on the bottom so i might go to a shop and give it a go and see if maybe i cut some of the plate at the top would there be any shot at avoiding holes.
Old Oct 6, 2025 | 11:42 AM
G. P's Avatar
2020 AMG GTC
Nice mounting design. .. and I have no intention to take away from your creative work...
I have used this removable bracket
Amazon.com: STO N SHO Front License Plate Bracket Compatible with 2019 Mercedes AMG GT 63 S without P88 Package : Automotive Amazon.com: STO N SHO Front License Plate Bracket Compatible with 2019 Mercedes AMG GT 63 S without P88 Package : Automotive
Here are my reasons for choosing a removable setup:
Avoiding Citations
I typically drive without the front plate. On the rare occasions I’ve been stopped, I’ve explained that I had removed it for a "car wash" or "maintenance" etc and forgot to reattach it. I keep the plate in the trunk, attach it on the spot, and in every instance, the officer has let me go without a fine.
Cooling and Performance
On hot track days, the front plate restricts airflow enough to raise engine temperatures more than necessary. Being able to remove it helps maintain better cooling.
Aesthetics
Simply put—it looks much cleaner without the front plate.
Old Oct 6, 2025 | 12:47 PM
untamedd's Avatar
2019 AMG GT R
I have used this removable bracket Amazon.com: STO N SHO Front License Plate Bracket Compatible with 2019 Mercedes AMG GT 63 S without P88 Package : Automotive
Avoiding Citations
Aesthetics
i like this idea even more and worth trying before resorting to drilling holes.
The link you shared above is for a 2019 GT 63S but im assuming the same one worked just fine on your GTC? Thanks
Old Oct 6, 2025 | 04:30 PM
untamedd's Avatar
2019 AMG GT R
Ok i didnt see any option on amazon but found one for a gtr on the stonsho website so i just ordered it.
now lets see if the cops here buy my story
Old Oct 6, 2025 | 07:21 PM
G. P's Avatar
2020 AMG GTC
It does fit the GTC. I have it on my GTC
You’ll need to drill a single hole at the top of the splitter to secure the screw. Start with a small pilot hole, then allow the screw to widen it to the proper size as you install it. Be sure to apply double-sided tape underneath the bracket..
Removable license plate on 2020 AMG GTC
Old Oct 6, 2025 | 07:24 PM
G. P's Avatar
2020 AMG GTC
The one on Amazon is actually Sto N Sho, so its the same
Old Oct 31, 2025 | 09:58 AM
untamedd's Avatar
2019 AMG GT R
finally got mine installed. Shop had to make a custom fit for it because of the front lip but it turned out fine because on the surface there are no visible signs:
Old Oct 31, 2025 | 10:06 AM
G. P's Avatar
2020 AMG GTC
Perfect. Nice job
