ThrottleHouse New Review - 2018 AMG GTR
Anyway, here in Europe, prices for the C190 series are definitely stable, if not slightly on the rise...
It could also be related to the tires (haven't watched it, yet). During the off-season, I dial each of the 3 the manual shock settings (2 bump, 1 rebound) almost off (because totally off results in a bump-squeak!) to soften up the ride during my "keep it lubed" runs. Even with that adjustment, once the temps get below about 15 deg C (60 deg F), the ride gets progressively more harsh. Below about 10 deg C (50 deg F) the ride can be more harsh (on some surfaces) than with the shocks set for track running when temps are 20 deg C (68 deg F) and higher. The rubber on Cup 2 tires becomes more like hockey-puck rubber at lower temps and (I believe) that's what contributes to the harsh ride (not that the GTR Pro's ride would ever be described as "really compliant" with Cup 2 tires).
My point is that these guys reside in Ontario and, if they did this review this fall, it may have been quite chilly and hardened the tires.
Back to the topic, tire pressure can play a role in ride quality too. Drop the pressure 5 degrees and it rides a LOT better. Stickier too!
I've never driven a GTR but I find the ride on my 17' GTS to be fairly compliant.
Sure hope he inflated the tires for the speed he was attaining on the autobahn.
Makes me miss Oregon with many similar tree lined roads.
https://youtu.be/biOOwRlmDAA?si=1grSiD6VKwFUb1Jv
If you lower the recommended cold tire pressure by 5 psi, you're at 26 psi. From the Michelin presentation I saw on Cup 2 tires, they advised to never run below 28 psi (for track days, I use http://car.dnsalias.com/stp for the initial-session setting).
