dusting??
is it ok to dust the car???...will it scratch the black paint??...if not, who makes a good duster?
also...i use the eagle 1 dry-as-you-wax when washing the car...is it just me or does this product accelerate the process of collecting dust??
what's a good product to use for detailing between washes that won't scratch the paint?
thanks in advance for your help.
john
The best known brand (California Car Duster) it can be used to remove pollen or light dust without causing scratches by applying very little surface pressure with the duster, dusting with long strokes in one direction only. Shake the duster occasionally to ensure any particles picked up will drop out rather than come to the surface while you’re using it.
It important to use the duster only for the removal of dry surface dust, if the vehicle has oily road film, road tar, damp pollen or dust, etc the vehicle surface should be washed
Dust build-up-with low humidity conditions friction on the paint surface will cause static electricity (this is exacerbated by the use of polyester (nylon) Microfiber) resulting in dust attraction to the paint surface. Rinsing the surface with water or applying a quick detailer (QD) or use the CCD as stated above to remove dust
When the duster is first purchased it should be wrapped in newspaper to remove any excess paraffin wax, the duster should not be washed, the dirtier it gets the better it works (I've been using mine now for almost five years without it being washed)
JonM
You can purchase a California Duster at you local Wal-Mart or Target. I'm sure it's also available in some auto parts stores.
JonM
As for it scratching, if you shake it after each pass and do not use it as a scrubber you will not get any scratching. Presently I have 2 black cars and the scratchiong is non existent.
Lou K
Kidding. Love the SLK55...walking to lunch the other day saw one and someone asked "what is that, a new Miata". I nearly soiled myself.
Just make sure you don't get too close to the rims and pick up any brake dust into the duster, otherwise feel free to use it on as many as you like...
Cheers.
