Washing Instruction
I use a combination of the California blade for the big areas and an "absorber" for the rest. One thing about the absorber is, if you wash it in a clothes washer don't use to much soap, or there may be residue soap left over and never-ever add softener in the wash. How do I know this....... the hard way of course.1991 300E 4Matic. Black of course.
I drive a black 91 300E, its my baby. last weekend i washed it with meguiars soap (dont recall which one it is, its pink..) then used rubbing compound, swirl remover, and finished it off with a layer or mother's wax. (i didnt buy any of this stuff, its sitting around at my parents house). any suggestions on improvement?
It looks great for a while, but when i park it at my apartment (not garaged) it gets so dusty in just 2 days. Is there any way i can prevent this?
I was thinking about trying the microfiber towels..but sounds like you need to wash it often...which is more of a hassle..requiring water,soap and electricty to wash the towels separately.
I also recommend people use mf terry cloths on their wheels too. as regular towels can leave scuff marks and sponges are just not practical in reaching tight spaces of the wheels.
No Way. all that grass gets on the wheels and paint and your shoes and hands. that's crazy. but to each his own. and nevermind the car wash chemicals in the storm drain which are mostly harmless as dish soap, that's why we have water treatment plants. our tax dollars is already taking care of that.
If at all, it should be the brake rotors one should be more worried about. It is not recommended for you to drive the car for a long time and then shortly after splash a good amount of water on the rotors when cleaning wheels.
currently moved here in san antonio from seattle for a year to save some money and wife attending school, i went from washing car every week to every month due to how dirty it gets days after i wash it..
i just went out there and told myself "what the f happend?"
so im going to wash her now, very helpful thread!
Problem is that I had a Rain Bird hose end nozzel that that a position on the nozzel for just the right amount of water. You could also change the setting for a more forceful setting. Unfortunately I ran over it moving the car one day and now I found that they quit making them and it seems that nobody has them.
Does anyone know of a hose end nozzle (pistol grip style) that has a good flood of water setting?
1 - Power wash car to remove lose surface dirt and grit.
2 - Wheels, tires & wheel wells: Pre-spray wheels with Sonax Wheel Cleaner. In first bucket of Detailer's Xtreme Foam, use Daytona Speed Master PRO Wheel Brush to clean spokes and wheel rims. First MF mitt to clean wheel face. Tire bush to clean both sides of tire. Handle brush to scrub wheel well. Rinse.
3 - The dirt belt (area from the side trim down): Pre-spray area to be cleaned with foam cannon filled with Detailer's Xtreme foam, using second MF mitt and two buckets of Detailer's Xtreme foam and grit guards (one for pre-rinse, one soap) work from side trim down - never move from dirty back to clean but from clean to dirty. Rinse.
4 - Wash entire vehicle from top down: Pre-spray area to be cleaned with foam cannon filled with Detailer's Xtreme foam, using third MF mitt and two clean buckets of Detailer's Xtreme foam and grit guards (one for pre-rinse, one soap) work from top down - never move from dirty back to clean but from clean to dirty. Rinse.
5 - Drying: OptiCoat is a highly hydrophobic coating, and you can dry the vehicle by simply sheeting a stream of water and "pulling" it down the car. Perfectly dry with no water spots. Dedicated leaf blower on low to blow water from trim and crevices, followed by Wolfgang's Detailer Spritz and MF towels dedicated to exterior drying only.
Takes about 90 minutes to complete. Absolutely no risk of introducing scratches or swirls, and your car will look showroom perfect. It may be a bit OCD - but if you've spent $100K on your car why trust it with a $20 wash??
I can't guarantee that in three years it'll look showroom perfect because I don't know the conditions on the road you drive, or if you have the patience to do everything it takes to keep your car looking its best.
I use mine as a daily driver, and after two years looks as good as the day it rolled out of Speedfreak's detail shop. I use Brian Lewis (aka Speedfreak) in Sterling, Virginia. One of the best in the business. Google his page, give him a call and discuss it with him. He's a good guy, glad to discuss car care, and will give you the straight gouge.
For my money I'd say go for it. I've done it with both my Benzos, and they constantly get compliments from people passing by. By the way - I'm out the door right now to give Gladys her weekly wash!
Cheers,
Greg
Cheers,
Greg
Brian Lewis (aka Speedfreak) is in Sterling, Virginia. But do give him a call, and tell him Greg with the CLK55 recommended.
Here's the deal, the OptiCoat is way tougher than your clear coat so it will preserve your clear coat, and makes the car far easier to clean - nice for x-country/DD. The 3M clear bra, while not bullet proof is FAR better than nothing.
Once you get your system down you can wash the car and have it dry in about 90 minutes. Additional time if you want to do anything extra.
Bottom line - well worth the investment. In the end your car will definitely look better with than without.
Let me know if you have any questions!
Greg
Greg
