spots on windshield
spots on windshield
Windshield is clear under sunny conditions! However, during a sun-shower a ghosting effect of what appears as dried rain-drops appears over the entire windshield. Visibility is reduced. Has anyone shared this experience? If so, what action did you take? The Factory Representative washed the windshield with BON-AMI. We await a rainstorm to see if it works. Your suggestions will be appreciated.
I've got the same thing. Looks like an inkblot test evertime there's rain. I've also got the problem that my windshield was replaced already with a stock unit, but not by a dealer. I'll have to try the serious cleanser thing on it eventually.
i had this same problem until i did the stoners + newspaper treatment. it took me 3-4 coats of this stuff to clean the windshielf, sunroof and rear windows; the side windows were clean in 1-2 coats.
C230 Sport Coupe
I have something similar that has yet to go away, but it is not nearly as bad. It is one drop on the windshield, one on the sunroof, and one on the rear window. It's almost like it was under something that dripped a corrosive or discoloring chemical onto it. It's been there since I've had the car.
We don't have rain here but if you really want to clean your windows well try Bar Keepers Friend. It's available at the supermarket. It's very strong but Crank & Chrome recommends it as a once a year thing to really get any stuck on bugs or chemical fallout or acid rain residue.
2002 C240
Re: spots on windshield
I first tried Stoners Invisible Glass, and although it helped a bit, the effects were not lasting. I then applied Bon Ami, followed by RainX.
Winshield wipes clean and water beads off nicely. Don't know if it was the Bon Ami, Rain X, or Both. Tried the Castrol spray on stuff and it didn't perform as well.
Volvo V90 CC
Those spots are usually created by "acid rain", on polluted cities when pollution starts accumulating (you don't need to see it) and rain starts comming down, rain is bringing the pollution down with it, it hits your winshield and car and those spots are developed. Most people don't clean the windows as much as they clean their car body. What to do to clean the spots, the best would be to polish the window, then wash it really good (to remove the polish). I know it sounds weird, but I'm from Mexico City I've seen and done this many times down there.
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
