Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
Old Jun 5, 2015, 01:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Car Detailing and Cleaning Guides
Print Wikipost
Ideas to repair paint chips
Old Mar 19, 2006 | 09:06 PM
Malesi1's Avatar
00 CLK 430
This spring I want my 00 CLK 430 cab to look perfect. The only real problems the finish has is small paint chips in the front end caused by stones. I have used the touch-up bottles, but the look is not great. I hate to have the whole front end painted, but is there any other way to make this repair without doing so?.
I am also planning on having the 3M clear protector installed professionally after the repair to prevent future damage.
Any ideas on the paint repaie would be appreciated...
Thanks, Mike....
PS color black opal
Old Mar 20, 2006 | 08:29 AM
TOGWT's Avatar
From: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
Paint Scratch / Chip Repair 103:
Paint Scratch / Chip Repair:
Why repair paint chips and scratches; to improve the vehicles appearance, to prepare vehicle for lease return, increase retail value and to protect the vehicle from further (corrosion) damage. Chips and scratches aren't just aesthetically unpleasing, the exposed metal underneath may be prone to rusting or additional chipping. Fixing these spots with touch-up paint is an easy step in protecting your investment-
Methodology
1.Apply isopropyl alcohol (ISP) to a Q-tip and dab on the rock chip or scratch a few times.
2.Take a clean towel and dry the paint chip.
3.With a utility knife cut the paint around the edge of the chip, the edge of the paint chip indentation will be slightly higher than the surrounding area and/or the edge of the chipped area may have separated from the metal surface or there could be some wax/dirt in the area or the paint may have oxidized on the edges (it is not absolutely necessary, but it does improve the results and will avoid leaving a dark outline)
4.Angle your blade toward the centre of the chip and press down gently. Work slowly and carefully, removing a small piece at a time, it’s not necessary to remove a lot of material. Clean the area with isopropyl alcohol (IPA) again and allow it to dry.
5.With painters masking tape cover the area surrounding the rust spot
6.Use Nikkens ™3000 grit finishing paper and a Unigrit Sanding Block sanding block to remove any rust
7.Use an AutoSharp paint pen (http://www.autosharppen.com) colour matched to your vehicle. The pen itself is very easy to use. You simply shake it, depress the felt tip a few times to start the paint flow, and then begin to "colour" paint into the damaged areas, much like you would highlight a section of text in a book.
8.Do not to try to fix the chip in one application, apply a small amount of paint and allow to dry, repeat over a couple of days. Once the painted area is slightly higher than paint surface, allow to dry.
9.Once completely dry, using a Nikkens™ 3000 grit finishing paper and a Unigrit Sanding Block (previously soaked for 4 hours or over night) to level touch-up paint with the surrounding paint surface
10.Use Woolite® or a car shampoo on the chip repair for lubrication.
11.Use a very light pressure on the sanding block, lightly wiping the area often to check your progress
12.Next, using a Nikkens™ 3000 grit finishing paper and a Unigrit Sanding Block to reduce the high spot off of the chip repair, using the block in one direction only. Do not use a circular motion (it will produce swirls) or a back and forth motion and ensure the sanding block is always wet
13.Keep the area well lubricated with water and shampoo; otherwise it will dull the paint. Once the surface appears level, use a block to squeegee off the excess water / slush (3M™ Wetordry™ Rubber Squeegee, P/N 05517, 2 ¾-inch x 4 ¼-inch) If the water you are using has a high mineral content, don't let it dry on the car, as it could leave spots which may bleed through the new paint.
14.Dry the surface with a clean towel and inspect with your fingertips.
15.If you can feel a high spot, repeat the sanding process.
16.If done correctly, you will hardly notice the repair.
17.A good car polish (Menzerna Intensive Polish or Menzerna Final Polish II ) will restore the paints lustre
18.Finally apply wax/sealant protection
Alternative products-
a) Lanka Paint chip and scratch repair technologies, is both a chemical and mechanical process, once the touch up paint has dried, The Blob Eliminator® will re-soften the paint, and the light rubbing mechanically begins to "smooth" down the excess paint, with the touch up paint now appearing on the cloth - http://www.langka.com/blob-eliminator-p-31.html
Langka and Metallic Paint-the reason metallic looks different after using the product is the metallic flakes migrate to the upper level of the paint surface while setting up. To counter this, use the blue sanding card on edge immediately after applying the touch up, like a razor. This will remove most of the touch up while the metallic flakes are still suspended evenly throughout the paint, smearing the excess across the local area. Let dry and use the Langka to wipe away the smear tail left across the original (OME) paint. - http://www.langka.com /
b) A system called Sprayless Scratch Repair- http://www.magictouchinc.com/
c) AutoSharp pen the pen itself is very easy to use. You simply shake it, depress the felt tip a few times to start the paint flow, and then begin to "colour" paint into the damaged areas, much like you would highlight a section of text in a book. http://www.autosharppen.com/
Paint chip repair companies- (UK) http://www.chipsaway.co.uk/index.asp
d) Touchup123- Use detailer’s clay on panel to be treated, Wipe on Final Touch Compound to prep surface,
Wipe Colorfill on ENTIRE panel to cover all the blemishes, Wipe on Final Touch Compound to remove excess Colorfill, Wipe off haze of Final Touch Compound to leave a polished shiny finish, Touch up any left over larger chips with a brush (can be built up and smoothed out later with Final Touch Compound if desired) - http://www.touchup123.com/
Metallic paints, silvers and gold’s, have to be applied with care to avoid problems with the "colour flop". Colour flop is the term given when metallic flakes in the chip reflect light giving you a lighter or darker appearance. This is a variable that cannot be controlled, for best results; shake the paint very well to get the metallic flakes evenly distributed before you apply
