help with weird spots
You may want to first talk w/ your dealer about exactly what was done to your car, show him the problem, and see if he will redo it correctly or, better yet, give your money back so that you can take it to a competent detail man.
On average, a high solid clear coat will absorb approximately one pint of water when the vehicle is subjected to a heavy rain or a car wash. If there is a "clouding" of the clear, simply applying isopropyl alcohol (IPA) to the area, allowing it to dwell and with a heat gun or hair dryer, heat the area (do not exceeding 100oF spot temperature) the IPA acts as a "drying" agent, and when combined with the heat the moisture will evaporate
