HOW TO REMOVE RESIN!my car looks terrible
MB SLK 200 Kompressor , BMW Z4
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
Hi all!!
its impossible to remove the tree resin from the surface(slk 200 kompressor), is there any special liquid to clean this sticky & hard gummy thing?Is it possible to prepare a mixture at home to remove this?or any other solution?
I'd be grateful if you can help me about this.I really need help,
Thank you very much
Thank you very much
WD40 is another option
I have used it often on the rocker panels for tar and other debris that gets stuck to the paint. It works well to soften up the hard deposits and makes them easy to clean off with quick detailer as the follow up.
JR
JR
tar remover doesnt work
Unfortunately tar remover doesnt help. Thanx for the tips , i will try bug remover .Some polishing , cleaning specialist companis like Ziebart , pro - car have that special cleaner to remove resine but they dont sell it.They supply only for their services to clean resine before polishing.I wish i could get that miracle product.
I will ask for the removel of the resin only.Usually they charge the complete service (inc polishing, isolation etc.) it sucks.
Mercedes-Benz
how long has it been on there? If tree sap isnt removed within 3 days it is going to be a pain to get off. If its been there for a few months, sanding is probably the only answer, i will look into this for u. Try some rubbing alcohol on it.
C32 AMG
Sounds like you need a solvent product. Products like 3M Adhesive Remover, Goo Gone, etc sound like they will work.
Probably the easiest thing to do is go to your hardware store at get some isopropyl or denatured alcohol. Denatured has a lot of other uses as well.
Thanx for your help
Alboston & Justin thanks for the tips .I think its been more than 1 month.Not sticky anymore but its damn hard now.I better keep on searching for an exact matching product.Chemicals sound a bit scary to me and i dont want to peel of the metallic paint...lol..
Thanx a lot for your help
BMW e46 320d Touring (DEBO)
You guys and all your methods jezus... All you need is some 95 gasoline and a rag soak the rag wish gasoline and rub the area that is covered with resin, tar etc. And it will be gone instantly.
