Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
Need Help Have Streaking Looks Like Grease ¿¿
Old Aug 18, 2006 | 09:16 PM
MR_560SEC's Avatar
2007-E350
Question Need Help Have Streaking Looks Like Grease ¿¿
hey guys i have a huge problem that is pi*sin me off.... i have a 3 month old black e class and i tried detailing it 3 times already and every time i detail it i have a streaking problem all over the car. i think its grease left over from the wax but not sure?
if any one know what this is please help me out and tell me how to take this crap off and what to do next. thanks.
Old Aug 18, 2006 | 11:22 PM
vader's Avatar
04 E55
Bet if you give Zaino's a try you will be pleased. Awsum stuff on silver and I would bet there are folks with black that will tell you the same.
Old Aug 19, 2006 | 10:49 AM
TOGWT's Avatar
From: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
Isopropyl alcohol (IPA)
Wash and tthen clean the paint surface with Isopropyl alcohol (IPA) also known as isopropanol, or rubbing alcohol contains 70% isopropyl alcohol, is a colourless liquid with a pleasant odour. It is highly flammable and is found in alcohol sponges, cleaning agents, and rubbing alcohol (although some rubbing alcohols contain ethanol) and is a good disinfectant.
Used in various dilutions it is used for removing adhesive residue, as a solvent for petroleum type stains. See relevant sections for usage and dilution used.Used after polishing to check the paint surface for any surface imperfections not removed by polishing.
Methodology
•Using a fine mist, spray the surface with a 1:1 solution distilled water and Isopropyl alcohol (IPA) an aqueous solution will also eliminate static electricity from the paint surface
•Leave it to dwell for 30-45 seconds, agitate the surface before wiping the paint surface with clean, dry 100% cotton (DF Alpine™) towel to remove sealant/wax residue.
•Repeat as necessary
•Place your fingertips on the paint surface, by running your finger tips along the surface there should be resistance (surface tension) this is indicative of a clean paint surface i.e. without any sealant / wax /oils.
Old Aug 19, 2006 | 04:06 PM
MR_560SEC's Avatar
2007-E350
how about if i just clay bar the car ?
Old Aug 20, 2006 | 03:48 PM
ElDiabloJoe's Avatar
'03 W211 aka E-500
You've detailed the car three times, and you haven't clayed? Then you haven't detailed the car even once.
EDJ
Old Aug 20, 2006 | 05:44 PM
MR_560SEC's Avatar
2007-E350
i told them to clay and they said it would ruin my paint since it was a new car.
Old Aug 20, 2006 | 08:11 PM
'03 W211 aka E-500
Oh, no wonder so many problems/questions. You're not doing this yourself.
You should really get some beer in the fridge, turn on a radio, and spend a good ol' fashioned American Saturday washing and waxing your car.
EDJ
