Need something to keep my wheel wells black
I've been looking for a product to use to make my wheel wells darker after I clean them. I've thought about using Mother's Back to Black but then started reading how it attracts dust. Thought about Armor All but I'm sure that would attract dust also. I've actually even thought about painting them with a flat black trim spray even! Anyways, if someone could recommend something that's not a dust magnet and lasts for a bit I would appreciate it!
for a black car what other colors did you have in mind? a nice paisley or orange or purple???
i know exactly what the OP is talking about. you spend hours on every single detail of the shine of the paint, make the interior perfect, get the windows a perfect streak free clean, and get your wheels and tires perfect and then you see the wheel well and it looks like crap and that is all you can see on an otherwise perfectly detailed car.
i would advise asking greg over at the detailed image, they have high quality stuff and i am sure there is a product that will make this task easy and look great.
Greg @ Detailed Image
Periodically remove the wheels (one at a time utilizing a car jack and / or axle stands) to enable cleaning the back of the wheel, callipers and give better access to the wheel wells. Ensure that the vehicle body is secure by placing on axle stands.
•Rinse wheel well thoroughly with water.
•Use a 1:1 solution of P21 Total Auto Wash a d-limonene (citrus) based cleaner and water in a spray bottle, spray the wheel wells and let the solution dwell for 3-5 min
•Agitate and brush the road dirt / grime the wheel well and suspension parts, brake callipers, etc
•Spray the area thoroughly with a high pressure water spray
•Repeat if necessary
•Use P21S Polishing Soap on all metal parts (taking care to avoid the brakes)
•Rinse using a high pressure hose / nozzle to remove soap residue
•I recommended wearing rubber gloves, once finished, rinse the wheel wells and dry them with an old terry towel.
•Once they have thoroughly dried spray them with Adam’s Undercarriage Detailer or Chemical Guys Bare Bones (avoid spraying the brake rotor) which leaves a matt finished look without grease and also provides a protection for the plastic - http//: www.adamspolishes.com / - http//:www.chemicalguys.com
For more information see article "Wheel Surface Cleaning” in the Detailing School section of Detailing Bliss forum...
