Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
Detailer's Domain: 2008 STI Mega Write Up!
Old Jul 20, 2009 | 11:09 PM
detailersdomain's Avatar
Former Vendor of MBWorld
08 STI
Here is the long awaited DD Subie Write up.
Where should I start, the mods I guess. Here is what I did before the complete detail was done. I researched and found all the parts I wanted to make this car look and handle a bit better.
Take a look at the work done, I did just about all the install work myself less the AV system and a few bushings (needed a press to get some of the stock ones out)
This car was a treat I never really did any of the wrenching myself so this was a great learning experience. One big lesson, the right tools and a lift are a HUGE Plus
Take a look:
Tuning mods:
Harman DP (removed when the car was traded in) not installed yet -installed and loving it 3/17/09
Harman Motive CAI
Magnaflow CBE --> removed
Invida Q300 CBE installed 3/2009
Access Port (stg 2)
Group N Engine Mount- installed 4/21/09
STI Heat Sheid
Exterior/interior:
Rally Armour Mud Flaps.-->deleted
Rear Bumper cargo strip (incoming) -
Arm rest extension (incoming) -installed 3/17/09
Rear Cargo Tray (incoming) - installed 3/17/09
Piaa Xtreme White Plus High Beams (9005)- installed 3/09
Piaa Plasma Ion Yellow Fogs -installed 3/28/09
Perrin Super Shorty Antenna - installed 3/28/09
Harman Motive Rear Overlay - installed 4/27/09
Valentine One - hardwired 4/27/09
Suspension:
BC BR CO's installed 3/2009
Whiteline Front Sways (22 mm) - installed 3/29/2009
Whiteline Rear Sways (20 mm) - installed 3/29/2009
Whiteline Sway Bar Support Brace - installed 3/29/09
Whiteline Anti-Lift Kit - installed 3/29/2009
Perrin Front End Links - installed 4/21/09
Perrin Rear End Links - installed 4/21/09
SPT STI Front Strut Bar - installed 4/27/09
SPT Lower H Chasis Brace - - installed 5/1/09
Whiteline 08+STi Positive Traction Kit- KDT902 - installed 5/1/09
Whiteline 08+ WRX Rear Differential Mount Inserts - KDT903 - installed 5/1/09
Whiteline rear camber adjusting kit 08+ wrx/sti hatchback subaru-kca326-- installed 5/1/09
Whiteline Steering Rack Bushing kit 08+ - ksr207 -- installed 5/1/09
Whiteline Rear Trailing Arm Bushing * W0568 -- installed 5/1/09
Whiteline Front Control Arm Bushings - W0507 -on the way
Stereo upgrades:
Kenwood DNX 7140 installed by Mobilewerks 4/7/09
JDM AV Panel installed 4/17/09
The car in stock form
At the dealer before delivery:
Old Jul 20, 2009 | 11:10 PM
08 STI
The STI at its first mobile detail job nice and dirty after a couple snow storms
Let the mods begin...
First up the CO's, Exhaust, and Removal of the Mud flaps
The BC Coilovers:
Old Jul 20, 2009 | 11:11 PM
08 STI
instructions and adjusters:
Install pictures:
Frt stock:
Set up and install:
Loosening up and removing
After shot:
Adjusters on the front
Rear install:
before:
after:
08 STI
Rear adjuster:
Invidia Q300 Install pictures:
the exhaust in the box:
Getting ready to remove the Magnaflow exhaust
Old exhaust removed:
Joe doing the final install
http://i46.photobucket.com/albums/f149/pyiu/08%20impreza%20sti/joeworkingontheexhaust.jpg[/IMG]
Mud flaps on the car:
Mud flaps off the car:
08 STI
Final shots of the car:
my favorite shot:
Next up the downpipes
Extended arm rest install
Extended
08 STI
Cargo Tray
Rear bumper guard
Tranny mounts
Sways, Tranny Mounts, Bushings all getting installed
Old Jul 20, 2009 | 11:12 PM
08 STI
More bushings
Support Brace
08 STI
Strut Bar
Endlinks
Shorty antenna install
Stock
50/50
After
Kenwood DNX-7140 Install (installed by the pro)
AV Panel from Japan
Stock panel with the new head unit
After with the new Japanese AV Panel
08 STI
Random stuff
Debadging the car
Dental Floss
Leftover adhesive and ghosting
3M adhesive remover was used
Old Jul 20, 2009 | 11:13 PM
08 STI
Compounding and polishing
Final before and after
Now onto the detail......
Products Used:
Exterior:
Adam's All Purpose Cleaner in the Cam Spray Foam Canon
Adam's Clay Bar and Optimum Instant Detail Spray and Gloss Enhancer for clay lube
Menzerna Super Intensive with the Uber Orange Pad
Menzerna PO85RD with the Uber Blue Pad
Menzerna Top Inspection
Lusso Prototype for Detailer’s Domain
Einszett Spray Wax
08 STI
Wheels and Tires
Uber Wheel/Tire/Wheel Well Kit see below for more of the wheel write up.
Interior and Glass
Adam's Glass Cleaner and Uber Glass MF Towels
Leather Master Foam Cleaner (alcantara)
Leather Master Nubuck Protection (alcantara)
Leather Master Strong Cleaner (leather)
Leather Master Vital (leather)
Engine:
P21S Total Autowash
Adam's VRT Diluted with Water in a Spray bottle
Trim:
Black Wow
Tools:
Infratech 5300
Brinkmann MaxFire
Metabo PE12-175
Makita 9227 Hi Speed Rotary
The Uber Foam Pads (5.5inch)
Tons of "Uber" Microfiber Towels
Uber Drying Towels
Cam Spray 1500A with Cam Spray Foam Gun
Let's start with the wheels.
Here is the set up, I have had the STI now for over 3000 miles and unfortunately I have had no time to give it even a proper wash, actually I haven't washed it yet. The day I figured I had some time it got just too hot to finish it. (98 degrees!)
Anyway here is a teaser. I got started on the wheels and after 3000 miles of caked on brake dust I decided to go all out!
By this I mean wheels were off the car, wheel wells were cleaned and dressed, brakes were polished and waxed.
Products used:
Uber Wheel Kit
Menzerna PO85RD
Sears Jack
19mm Socket
Ratchet
Torque Wrench
Cam Spray Pressure Washer
Now to the pictures:
Before shots of the wheels.
Before Brakes and Wheel Wells. (reference left side, forgot to take all the complete shots, both sides were pretty dirty)
Wheel being pulled off using ratchet and jack.
Wheel off the car.
Back
P21S Gel on the wheels, I let it dwell while I cleaned the wheel wells and brakes
Back of the wheel
08 STI
Front of the wheel
What it looks like after P21S sits for a while, the P21S Wheel Gelis pretty thick.
Cleaned both the front side and the back side with the Uber Boar's Hair Wheel Brush, The Uber Spoke Brush, and the Swissvax Wheel Brush, each one helped with the process of cleaning all that brake dust and dirt off the wheels.
Old Jul 20, 2009 | 11:14 PM
08 STI
After I applied Swissvax Autobahn on them.
Results from all that hard work on the wheels.
Now that the wheels were done...on to the wheel wells.
P21S Total Auto Wash was used to cut the dirt and grime off the wheel wells as well as the suspension bits, and brake calipers.
Brushes were used to help clean up the wheel wells etc
After everything was rinsed and cleaned up, I moved on to polishing the brake calipers with Menzerna PO85RD after I put a nice coat of Swissvax Autobahn on them to give them a nice shine and protection.
08 STI
Caliper After Polish and before Autobahn
Applying the SV Autobahn
Removing the SV Autobahn
Adam's Undercarriage Spray was applied to bring back a nice new look to the wheel well covers (note I did wipe down any access to prevent a oily greasy look, I was going for a matte finish)
08 STI
Rear Before
Rear After
Front Before
Old Jul 20, 2009 | 11:15 PM
08 STI
Front After
After of the wheel back on the car (less the tire dressing)
Of course the wheels were done again but much easier this time around.
Take a look.
Let's do the interior first
Before
08 STI
After
Old Jul 20, 2009 | 11:16 PM
08 STI
Prep
Some before shots (this is how I got the car from the dealer)
08 STI
Before engine shots
Cleaning up the engine
Old Jul 20, 2009 | 11:17 PM
08 STI
P21S Total Autowash on all the areas with wax build up around the rubber trim, bug and tar etc.
Now for the foam canon
Claying the car
Swirls everywhere
Old Jul 20, 2009 | 11:18 PM
08 STI
Measuring paint
After polishing under the Brinkmann
After shots of the engine
After shots of the car
08 STI
Last shot
