Somebody keyed my car. :(
Kevin
watch your pressure
, if the scratch is too deep don`t try to remove it , made it hard to see and use wax with fillers .....
Good Luck!
Wax will not fill or correct so you need something with some grit to polish it out.
Rule of thumb is always start with the least abrasive product first and move up to more aggressive compounds if that does not work.
If you are not comfortable with trying it yourself, a good body shop should not charge you too much to correct.
MB paints are hard and their cermamic clear coat can be tough to work on if you are not used to them, so proceed with care and/or get it done professionally.
