Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
water marks
Old Mar 6, 2010 | 11:59 PM
PH1L's Avatar
CLK w209 GLC43 coupe
water marks
Hi,
Im just wondering how to get rid of the water marks.. like no matter how many times i wash my car... wax.. its still there.. so i would be great if someone tell me how to get rid of it
thaks
phil
Old Mar 7, 2010 | 04:24 AM
xxxv8's Avatar
SL55
Originally Posted by PH1L
Hi,
thaks
phil
I use Meguiars paint cleaner using a buffing sponge. Does the job really well.
Old Mar 7, 2010 | 11:19 AM
MoeMistry's Avatar
Former Vendor of MBWorld
NA
Hi,
thaks
phil
Can you post some pictures Phil? It may be something as simple as a good hand polish, or it may require machine polishing. But wax won't take off water spots...it has no abrasive properties.
Old Mar 7, 2010 | 11:56 AM
B on my Benz's Avatar
E.FIDDY.FIVE AMG
Yea buffing with a great compound will def get rid of those water marks.
Old Mar 7, 2010 | 12:09 PM
MoeMistry's Avatar
NA
Compounding should be one of the last resorts. A good hand polish takes care of most water spots. No need for a sledgehammer to drive in a small nail.
Old Mar 8, 2010 | 08:25 AM
PH1L's Avatar
okay thanks alot guys.. ill try to polish it and see how it goes from there
thank you very much again
phil
Old Mar 8, 2010 | 10:43 AM
Envious Eric's Avatar
Nissan xterra
vinegar, water spot remover, cleaner wax like megs #66, clay...those are all other options I would try before compounding. If none work, then its time for the machine and a polish to come out, then the compound
Old Mar 8, 2010 | 11:15 AM
TOGWT's Avatar
From: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
Use the least abrasive product first-
1. Use a paint surface cleaner (Z-PC Fusion Dual Action Paint Cleaner or Duragloss 501)
2. Try to dissolve the alkaline-based, surface/etched mineral water deposits try one or more of the following;
a) Use a 2:1 or stronger solution of distilled water/distilled white vinegar (Acetic acid)
b) Try a 2:1 solution of distilled water/Isopropyl Alcohol (adjust ratio as required)
c) Or equal parts distilled water/distilled white vinegar/Isopropyl alcohol.
3. Clean the effected surface with Klasse All-In-One or Zaino Z-PC Fusion Dual Action Paint Cleaner
4. Use detailing clay to remove any `hard' surface granules
5. Use a machine polish (Optimum Polish, Optimum Compound) and a cutting (LC White, Orange or Yellow) foam pad (speed # 4- 5.0) to level the paint surface
6. For Ceramiclear or other hard clear coats substitute Menzerna for machine polish; Super Intensive Polish / Nano Polish (105FF) or Final Finish Polish (106FA)
7. Use the least aggressive polish/foam pad first, if this doesn’t remove the problem step-up to a more aggressive polish / foam pad set-up
8. Menzerna Power Finish (PO203S) - (M) this is a one-step scratch remover polish is formulated for CeramiClear or other ‘Hard’ paints. It will remove 2500 grit, cut 3.0-gloss 3.5, is formulated as a quick way to polish out light flaws and amplify the paint’s gloss. Use a primed Orange (mid range, high density foam (60 PPI) medium abrasive cutting action LC CCS foam pad 1200 RPM
9. Wet-sand with 2000, 2500 or 3000 grit finishing paper
Old Mar 8, 2010 | 01:25 PM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
I used a clay bar and some 3M swirl remover polish and it worked wonders.
Old Mar 10, 2010 | 01:32 PM
pushtiulk's Avatar
2007 Fiat Panda 1.3 JTD
Great info!
